<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[slicing with OpenJSCAD]]></title><description><![CDATA[<p dir="auto">Hello, I'm using OpenJSCAD to slice a model to laser cut it and it works fine on a model with 1000 triangles. I use the SVG export directly and that's very nice, even if there's little editing to do before to export to gcode and cut.</p>
<p dir="auto"><img src="/assets/uploads/files/1562227599749-capture-d-%C3%A9cran-de-2019-07-02-14-48-00-resized.png" alt="1_1562227595287_Capture d’écran de 2019-07-02 14-48-00.png" class=" img-fluid img-markdown" /> <img src="/assets/uploads/files/1562227599144-capture-d-%C3%A9cran-de-2019-07-04-10-00-28-resized.png" alt="0_1562227595286_Capture d’écran de 2019-07-04 10-00-28.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://openjscad.nodebb.com/topic/101/slicing-with-openjscad</link><generator>RSS for Node</generator><lastBuildDate>Fri, 16 Oct 2026 05:03:15 GMT</lastBuildDate><atom:link href="https://openjscad.nodebb.com/topic/101.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 04 Jul 2019 08:08:18 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to slicing with OpenJSCAD on Tue, 30 Jul 2019 08:03:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kaosat-dev" aria-label="Profile: kaosat-dev">@<bdi>kaosat-dev</bdi></a> At first I tried to use a 10K triangles model but as it didn't render I downscaled to 5K, 3K, 2K then 1K. And after, I made another model with 2x more slices that this script was unable to render even with a 1K model, so I changed the script to make it render chunks of slices, and it was ok. I suppose it could work with higher resolutions models.<br />
<img src="/assets/uploads/files/1564473767423-capture-d-%C3%A9cran-de-2019-07-30-10-02-14-resized.png" alt="0_1564473765365_Capture d’écran de 2019-07-30 10-02-14.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://openjscad.nodebb.com/post/170</link><guid isPermaLink="true">https://openjscad.nodebb.com/post/170</guid><dc:creator><![CDATA[gilboonet]]></dc:creator><pubDate>Tue, 30 Jul 2019 08:03:26 GMT</pubDate></item><item><title><![CDATA[Reply to slicing with OpenJSCAD on Tue, 30 Jul 2019 06:20:31 GMT]]></title><description><![CDATA[<p dir="auto">This is absolutely amazing, both from a technical and a design point of view ! big kudos !</p>
<p dir="auto">it works fine on a model with 1000 triangles</p>
<p dir="auto">I am guessing it does not scale particularly well ? <img src="https://openjscad.nodebb.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=4619dfc2edd" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /></p>
]]></description><link>https://openjscad.nodebb.com/post/169</link><guid isPermaLink="true">https://openjscad.nodebb.com/post/169</guid><dc:creator><![CDATA[kaosat-dev]]></dc:creator><pubDate>Tue, 30 Jul 2019 06:20:31 GMT</pubDate></item><item><title><![CDATA[Reply to slicing with OpenJSCAD on Fri, 05 Jul 2019 08:35:14 GMT]]></title><description><![CDATA[<p dir="auto">finished <img src="/assets/uploads/files/1562315706956-tranches_fini_ok-resized.jpg" alt="0_1562315703407_tranches_fini_ok.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://openjscad.nodebb.com/post/167</link><guid isPermaLink="true">https://openjscad.nodebb.com/post/167</guid><dc:creator><![CDATA[gilboonet]]></dc:creator><pubDate>Fri, 05 Jul 2019 08:35:14 GMT</pubDate></item><item><title><![CDATA[Reply to slicing with OpenJSCAD on Thu, 04 Jul 2019 10:47:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/z3dev" aria-label="Profile: z3dev">@<bdi>z3dev</bdi></a> I'm making the statue <img src="/assets/uploads/files/1562237227721-assemblage_en_cours-resized.jpg" alt="0_1562237224930_assemblage_en_cours.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://openjscad.nodebb.com/post/166</link><guid isPermaLink="true">https://openjscad.nodebb.com/post/166</guid><dc:creator><![CDATA[gilboonet]]></dc:creator><pubDate>Thu, 04 Jul 2019 10:47:23 GMT</pubDate></item><item><title><![CDATA[Reply to slicing with OpenJSCAD on Thu, 04 Jul 2019 10:41:16 GMT]]></title><description><![CDATA[<p dir="auto">Very interesting indeed.</p>
<p dir="auto">What are you going to do with all of those slices?</p>
]]></description><link>https://openjscad.nodebb.com/post/165</link><guid isPermaLink="true">https://openjscad.nodebb.com/post/165</guid><dc:creator><![CDATA[z3dev]]></dc:creator><pubDate>Thu, 04 Jul 2019 10:41:16 GMT</pubDate></item></channel></rss>
