<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[V2 Update]]></title><description><![CDATA[<p dir="auto">We are happy to annouce that a pre-release "alpha' version of JSCAD V2 is now available from GitHub. There will be weekly updates to the pre-release so please stay up to date.</p>
<p dir="auto">And if all goes well, publishing to NPM will also be enabled.</p>
<p dir="auto">Latest updates include:</p>
<li>corrections to the order of transforms (translate, scale, etc)</li>
<li>primitives (circle, cube, etc) accept a center option again</li>
<li>NEW curves generation, which includes bezier curves for generating 3D points</li>
<li>fixes to the WEB UI</li>
<li>fixes to extrude and offset</li>
<p dir="auto">The WEB UI is now quite usable for creating designs. It's best to drag-n-drop project folders to the window, and work with the pieces via a favorite editor. If "Enable auto reload" is checked then changes will be detected, and rendered again.</p>
<p dir="auto">For those wanting to get hold of JSCAD V2, it's still in 'early adoption' mode. But you can get started <a href="https://openjscad.org/dokuwiki/doku.php?id=early_v2" rel="nofollow ugc">here</a>.</p>
<p dir="auto">And a BIG THANKS to all the early adopters. Keep those comments coming!</p>
]]></description><link>https://openjscad.nodebb.com/topic/146/v2-update</link><generator>RSS for Node</generator><lastBuildDate>Mon, 18 May 2026 03:31:19 GMT</lastBuildDate><atom:link href="https://openjscad.nodebb.com/topic/146.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 24 Aug 2020 02:32:15 GMT</pubDate><ttl>60</ttl></channel></rss>
