<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Initial release of FlexiSystem]]></title><description><![CDATA[<p dir="auto">I made a static version of my project and got it up and running on Github page:<br />
<a href="https://gitpharm01.github.io/FlexiSystem/" rel="nofollow ugc">https://gitpharm01.github.io/FlexiSystem/</a></p>
<p dir="auto">This is a prototype modelling system to create flexi models like this:<br />
<img src="/assets/uploads/files/1602510445843-38.png" alt="38.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">This system is powered by the JSCAD but require zero knowledge in programming.<br />
The user can make 3D models simply by mouse clicks.<br />
<img src="/assets/uploads/files/1602510627547-02.png" alt="02.png" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1602510641269-04.png" alt="04.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">You can go through the picture tutorial by pressing the "Tutorials here!" button to learn how to use it.<br />
I've made some test models and printed them successfully.<br />
If you made yours, please do share it on this post!</p>
<p dir="auto">This project is still in very early stage.<br />
The current issue I'm working on is to make the "joint templates" deletable.<br />
If you have any comment or suggestions, please let me know.</p>
]]></description><link>https://openjscad.nodebb.com/topic/175/initial-release-of-flexisystem</link><generator>RSS for Node</generator><lastBuildDate>Mon, 07 Sep 2026 02:48:51 GMT</lastBuildDate><atom:link href="https://openjscad.nodebb.com/topic/175.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 12 Oct 2020 14:00:35 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Initial release of FlexiSystem on Sat, 17 Oct 2020 03:02:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/z3dev" aria-label="Profile: z3dev">@<bdi>z3dev</bdi></a>  Got it! I'll try to update the engine with this:<br />
<a href="https://github.com/jscad/OpenJSCAD.org/tree/master/packages/web" rel="nofollow ugc">https://github.com/jscad/OpenJSCAD.org/tree/master/packages/web</a></p>
]]></description><link>https://openjscad.nodebb.com/post/472</link><guid isPermaLink="true">https://openjscad.nodebb.com/post/472</guid><dc:creator><![CDATA[Cid Zhang]]></dc:creator><pubDate>Sat, 17 Oct 2020 03:02:11 GMT</pubDate></item><item><title><![CDATA[Reply to Initial release of FlexiSystem on Thu, 15 Oct 2020 07:50:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cid-zhang" aria-label="Profile: Cid-Zhang">@<bdi>Cid-Zhang</bdi></a> Wow. I strongly suggest using V1 of OpenJSCAD. The old old old version at <a href="http://joostn.gihub.io" rel="nofollow ugc">joostn.gihub.io</a> is not maintained.</p>
]]></description><link>https://openjscad.nodebb.com/post/452</link><guid isPermaLink="true">https://openjscad.nodebb.com/post/452</guid><dc:creator><![CDATA[z3dev]]></dc:creator><pubDate>Thu, 15 Oct 2020 07:50:04 GMT</pubDate></item><item><title><![CDATA[Reply to Initial release of FlexiSystem on Thu, 15 Oct 2020 04:20:56 GMT]]></title><description><![CDATA[<p dir="auto">Currently I have some issues with the development and I need some advice.</p>
<p dir="auto"><strong>The first problem</strong> is that I'm using jscad in a <strong>strange way</strong>.<br />
I seperated the jscad script into two parts.</p>
<p dir="auto">One part is the backbone of the script, which locates at file:<br />
<a href="https://github.com/gitpharm01/FlexiSystem/blob/main/examples/flexi.jscad" rel="nofollow ugc">https://github.com/gitpharm01/FlexiSystem/blob/main/examples/flexi.jscad</a></p>
<p dir="auto">Another part is created according to the user's input, like points of the shape and positions of the hinges/joints.<br />
It's done by "function update3DScript()" in file:<br />
<a href="https://github.com/gitpharm01/FlexiSystem/blob/main/javascripts/flexiBase.js" rel="nofollow ugc">https://github.com/gitpharm01/FlexiSystem/blob/main/javascripts/flexiBase.js</a></p>
<p dir="auto">These two part will be merged into one and stored in a text area in the index.html.<br />
And then the completed script will be loaded by a OpenJsCad.Processor object which is defined in the index page.</p>
<p dir="auto">This approach made the process complicated, but I can't find other way to do it.</p>
<p dir="auto"><strong>The second problem</strong> is about the version of JSCAD.<br />
There are many different versions of it and I don't know which one to choose.<br />
I'm currently using this version from joostn:<br />
<a href="http://joostn.github.io/OpenJsCad/" rel="nofollow ugc">http://joostn.github.io/OpenJsCad/</a><br />
For better support and performance, is there a better version?</p>
]]></description><link>https://openjscad.nodebb.com/post/450</link><guid isPermaLink="true">https://openjscad.nodebb.com/post/450</guid><dc:creator><![CDATA[Cid Zhang]]></dc:creator><pubDate>Thu, 15 Oct 2020 04:20:56 GMT</pubDate></item><item><title><![CDATA[Reply to Initial release of FlexiSystem on Thu, 15 Oct 2020 04:18:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hrgdavor" aria-label="Profile: hrgdavor">@<bdi>hrgdavor</bdi></a><br />
I labelled it with a  Apache License 2.0 in the repository.<br />
But be careful that some part of it came from reverse engineering of a website which gone offline this year.</p>
]]></description><link>https://openjscad.nodebb.com/post/449</link><guid isPermaLink="true">https://openjscad.nodebb.com/post/449</guid><dc:creator><![CDATA[Cid Zhang]]></dc:creator><pubDate>Thu, 15 Oct 2020 04:18:10 GMT</pubDate></item><item><title><![CDATA[Reply to Initial release of FlexiSystem on Wed, 14 Oct 2020 01:03:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cid-zhang" aria-label="Profile: Cid-Zhang">@<bdi>Cid-Zhang</bdi></a> Super nice! I will play with it and post back. Fun fun!</p>
]]></description><link>https://openjscad.nodebb.com/post/439</link><guid isPermaLink="true">https://openjscad.nodebb.com/post/439</guid><dc:creator><![CDATA[z3dev]]></dc:creator><pubDate>Wed, 14 Oct 2020 01:03:31 GMT</pubDate></item><item><title><![CDATA[Reply to Initial release of FlexiSystem on Tue, 13 Oct 2020 09:21:51 GMT]]></title><description><![CDATA[<p dir="auto">nice prototype <img src="https://openjscad.nodebb.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=4619dfc2edd" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /></p>
<p dir="auto">is it opensource ?</p>
]]></description><link>https://openjscad.nodebb.com/post/435</link><guid isPermaLink="true">https://openjscad.nodebb.com/post/435</guid><dc:creator><![CDATA[hrgdavor]]></dc:creator><pubDate>Tue, 13 Oct 2020 09:21:51 GMT</pubDate></item></channel></rss>
