<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[V2 Feedback : require selection from parameter]]></title><description><![CDATA[<p dir="auto">I have a script that makes a volume from two svg files that are chosen from text parameters. Then a require is made from those parameters. Won't it be possible to have a list parameter that can be feeded from file names (naturally from project folder) filtered by a mask (like *.svg or profil??.svg ) ?<br />
<img src="/assets/uploads/files/1602619591670-capture-d-%C3%A9cran-de-2020-10-13-21-57-40.png" alt="Capture d’écran de 2020-10-13 21-57-40.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://openjscad.nodebb.com/topic/177/v2-feedback-require-selection-from-parameter</link><generator>RSS for Node</generator><lastBuildDate>Wed, 18 Nov 2026 04:40:42 GMT</lastBuildDate><atom:link href="https://openjscad.nodebb.com/topic/177.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 13 Oct 2020 20:06:58 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to V2 Feedback : require selection from parameter on Sat, 17 Oct 2020 15:52:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/z3dev" aria-label="Profile: z3dev">@<bdi>z3dev</bdi></a> I could easily adapt to any solution allowing to feed a list parameter with files, it will be far a better UI practice than my current one that requires the user to type the file name. Or maybe the ability for a text parameter to receive a file from a drag-drop operation.</p>
]]></description><link>https://openjscad.nodebb.com/post/473</link><guid isPermaLink="true">https://openjscad.nodebb.com/post/473</guid><dc:creator><![CDATA[gilboonet]]></dc:creator><pubDate>Sat, 17 Oct 2020 15:52:16 GMT</pubDate></item><item><title><![CDATA[Reply to V2 Feedback : require selection from parameter on Wed, 14 Oct 2020 01:15:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gilboonet" aria-label="Profile: gilboonet">@<bdi>gilboonet</bdi></a> nice idea.</p>
<p dir="auto">of course, design parameters are defined by getParameterDefinitions(), but internally this function can call other functions, do calculations, etc. i would expect that loading JSON files should be easy.</p>
<p dir="auto">if you want access to a list of files in a subfolder... hold on... there's are some changes in progress. <img src="https://openjscad.nodebb.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f913.png?v=4619dfc2edd" class="not-responsive emoji emoji-android emoji--nerd_face" style="height:23px;width:auto;vertical-align:middle" title=":nerd_face:" alt="🤓" /></p>
]]></description><link>https://openjscad.nodebb.com/post/440</link><guid isPermaLink="true">https://openjscad.nodebb.com/post/440</guid><dc:creator><![CDATA[z3dev]]></dc:creator><pubDate>Wed, 14 Oct 2020 01:15:09 GMT</pubDate></item></channel></rss>
