<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Cylinder between points?]]></title><description><![CDATA[<p dir="auto">At the risk of being a pain in the neck (or choose other part of the body) with all my current enquiries, I have another one.  In V1, and in CSG, we had the (for me) very useful functionality of being able to construct a cylinder between two given points.  This does not seem to exist in V2.  Now I know that a cylinder between two points can be constructed first by determining a height as the Euclidean distance between the points, and width, and then using appropriate rotations and a translation to move it into its place.  But this is a non-trivial task (how would you construct a cylinder between (-2,3,5) and (-4,-1,7) for example?) which would be rendered much easier by being able to construct a cylinder between two points.  Will this be added, or is this one of those libraries to be added by users to make up any loss of functionality from V1 and CSG?  (<em>We expect REMOVED functionality to be supported via small user libraries.</em>)  If so, I'd better get to work!</p>
<p dir="auto">Thanks,<br />
Alasdair</p>
]]></description><link>https://openjscad.nodebb.com/topic/183/cylinder-between-points</link><generator>RSS for Node</generator><lastBuildDate>Sat, 11 Jul 2026 20:58:36 GMT</lastBuildDate><atom:link href="https://openjscad.nodebb.com/topic/183.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 20 Oct 2020 01:15:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Cylinder between points? on Sat, 23 Jan 2021 12:57:58 GMT]]></title><description><![CDATA[<p dir="auto">I have sth with this function <img src="https://openjscad.nodebb.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=552b9a4dc0c" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /></p>
<p dir="auto"><a href="https://jscad.xyz/#https://gist.githubusercontent.com/hrgdavor/c63e34f862aab00cf9253daf2e071812/raw/acbefbcbbb47d7c0e4daf41c5c9be3d43062c56c/tesseract.jscad" rel="nofollow ugc">https://jscad.xyz/#https://gist.githubusercontent.com/hrgdavor/c63e34f862aab00cf9253daf2e071812/raw/acbefbcbbb47d7c0e4daf41c5c9be3d43062c56c/tesseract.jscad</a></p>
<p dir="auto"><img src="/assets/uploads/files/1611406672884-124e5f29-a4fb-40da-b9da-b2b044565b11-image.png" alt="124e5f29-a4fb-40da-b9da-b2b044565b11-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://openjscad.nodebb.com/post/621</link><guid isPermaLink="true">https://openjscad.nodebb.com/post/621</guid><dc:creator><![CDATA[hrgdavor]]></dc:creator><pubDate>Sat, 23 Jan 2021 12:57:58 GMT</pubDate></item><item><title><![CDATA[Reply to Cylinder between points? on Sun, 01 Nov 2020 15:10:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/alasdair-mcandrew" aria-label="Profile: Alasdair-McAndrew">@<bdi>Alasdair-McAndrew</bdi></a><br />
I tried to find code that does this exactly, but failed. So I took some time try different combinations of atan acos asin until I got somewhat working solution. Then I added fixes for special cases that break the inital code.</p>
<p dir="auto">based on your suggestion I tried some values (<code>dx=0</code>, <code>dy=0</code>, <code>dz=0</code>) and found a case that did not work: <code>(dx==0 &amp;&amp; dy == 0)</code>.<br />
I have added an exception that now fixes taht edge case.</p>
<p dir="auto"><em>(I am proud I made this work somehow, so if you find another edge case that does not work, let me know <img src="https://openjscad.nodebb.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=552b9a4dc0c" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /><br />
)</em><br />
link1: gist: <a href="https://gist.github.com/hrgdavor/c1bc1b4f3e3f92161eb4dd9074363793" rel="nofollow ugc">https://gist.github.com/hrgdavor/c1bc1b4f3e3f92161eb4dd9074363793</a></p>
<p dir="auto">link2: jscad.xyz with that gist: <a href="https://jscad.xyz/#https://gist.githubusercontent.com/hrgdavor/c1bc1b4f3e3f92161eb4dd9074363793/raw/1c41bbf3dc5d5af33614205ce8bd17e1e93b66f1/testCylinderFromTo.js" rel="nofollow ugc">https://jscad.xyz/#https://gist.githubusercontent.com/hrgdavor/c1bc1b4f3e3f92161eb4dd9074363793/raw/1c41bbf3dc5d5af33614205ce8bd17e1e93b66f1/testCylinderFromTo.js</a></p>
<p dir="auto">new version with fix:</p>
<pre><code>function cylinderFromTo(p1,p2, radius){
  const sqr = x=&gt;x*x
  let dx = p2[0] - p1[0]
  let dy = p2[1] - p1[1]
  let dz = p2[2] - p1[2]
  let height = Math.sqrt( sqr(dx) + sqr(dy) + sqr(dz))
  let obj = cylinder({radius, height})
  if(dx || dy){
    let dxy = Math.sqrt( sqr(dx) + sqr(dy))
    let ay = Math.atan(dxy/dz) *(dx &lt; 0 ? -1:1)
    let az = Math.atan(dy/dx)
    let ax = dz &lt; 0 ? -Math.PI:0
    obj = transforms.rotate([ax,ay,az], obj)
  let mid = [p1[0]+dx/2,p1[1]+dy/2,p1[2]+dz/2]
  return translate(mid, obj)
<p dir="auto">the code now works for all of these:</p>
<pre><code>  testCylinderFromTo([-20,30,50],[-40,-10,70]);
  testCylinderFromTo([0,0,0],[10,10,10])
  testCylinderFromTo([0,0,0],[20,-20,20])
  testCylinderFromTo([0,0,0],[-30,30,30])
  testCylinderFromTo([0,0,0],[-40,-40,40])
  testCylinderFromTo([0,0,0],[15,15,-15])
  testCylinderFromTo([0,0,0],[25,-25,-25])
  testCylinderFromTo([0,0,0],[-35,35,-35])
  testCylinderFromTo([100,0,0],[100,0,30])
  testCylinderFromTo([100,0,0],[100,0,-30])
  testCylinderFromTo([100,0,0],[100,30,0])
  testCylinderFromTo([100,0,0],[100,-30,0])
  testCylinderFromTo([100,0,0],[130,0,0])
  testCylinderFromTo([100,0,0],[70,0,0])
<p dir="auto">screen:<br />
<img src="/assets/uploads/files/1604242597307-89b64d1c-72a9-45ea-b018-2a1343030f72-image.png" alt="89b64d1c-72a9-45ea-b018-2a1343030f72-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://openjscad.nodebb.com/post/512</link><guid isPermaLink="true">https://openjscad.nodebb.com/post/512</guid><dc:creator><![CDATA[hrgdavor]]></dc:creator><pubDate>Sun, 01 Nov 2020 15:10:04 GMT</pubDate></item><item><title><![CDATA[Reply to Cylinder between points? on Sun, 01 Nov 2020 08:42:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hrgdavor" aria-label="Profile: hrgdavor">@<bdi>hrgdavor</bdi></a> That looks terrific!  I'm working on a similar one, but trying to see what happens if two of the coordinates are equal, or zero.   That is, if the x-coordinates of p1 and p2 are equal, or the y-coordinates, etc.  Or if some of them are zeros.  For example, in your computations of ay and az, you're using an inverse tangent, but what happens if either dx = 0, or dz = 0?</p>
<p dir="auto">I decided to first translate p1 and p2 to 0 and p2-p1 or p1-p2, depending on which had a positive z-coordinate.  Then we are simply rotating things in the z&gt;=0 half-space, which reduces everything to two rotations (as you have).</p>
<p dir="auto">But I do like the simplicity and elegance of your code: clearly you're a more advanced JavaScript programmer than me.  Did you work all this out from scratch, or are you taking another program and rewriting it?</p>
<p dir="auto">The other possible issue is that the result should be independent of the order of p1 and p2: it may be that your function does that automatically, but I found it tricky with mine.</p>
<p dir="auto">Thank you very much indeed.</p>
]]></description><link>https://openjscad.nodebb.com/post/511</link><guid isPermaLink="true">https://openjscad.nodebb.com/post/511</guid><dc:creator><![CDATA[Alasdair McAndrew]]></dc:creator><pubDate>Sun, 01 Nov 2020 08:42:06 GMT</pubDate></item><item><title><![CDATA[Reply to Cylinder between points? on Sun, 25 Oct 2020 22:42:39 GMT]]></title><description><![CDATA[<p dir="auto">I thought it would be fun to make such function.</p>
<p dir="auto">It is  a product of using atan acos asin until I got something and then guessing some more until it worked <img src="https://openjscad.nodebb.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f604.png?v=552b9a4dc0c" class="not-responsive emoji emoji-android emoji--smile" style="height:23px;width:auto;vertical-align:middle" title=":D" alt="😄" /> <img src="https://openjscad.nodebb.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f604.png?v=552b9a4dc0c" class="not-responsive emoji emoji-android emoji--smile" style="height:23px;width:auto;vertical-align:middle" title=":D" alt="😄" /> . It seems to be working, though I actually dont understand it completely <img src="https://openjscad.nodebb.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f604.png?v=552b9a4dc0c" class="not-responsive emoji emoji-android emoji--smile" style="height:23px;width:auto;vertical-align:middle" title=":D" alt="😄" /></p>
  return translate(mid, rotate([ax,ay,az], obj))
<p dir="auto">I used these to test visually</p>
<pre><code>function main(){
  ret = [];
  function testCylinderFromTo(p1,p2){
    ret = [ ...ret,
      translate(p1,sphere({size:1})),
      translate(p2,sphere({size:1})),
      jscad.colors.colorize([1,0,0,0.7],cylinderFromTo(p1,p2,2)),
  testCylinderFromTo([0,0,0],[-45,-45,-45])
  return ret;
<p dir="auto"><img src="/assets/uploads/files/1603663138778-dfcce911-bb6b-4b76-89c9-fb004be17564-image.png" alt="dfcce911-bb6b-4b76-89c9-fb004be17564-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://openjscad.nodebb.com/post/497</link><guid isPermaLink="true">https://openjscad.nodebb.com/post/497</guid><dc:creator><![CDATA[hrgdavor]]></dc:creator><pubDate>Sun, 25 Oct 2020 22:42:39 GMT</pubDate></item><item><title><![CDATA[Reply to Cylinder between points? on Tue, 20 Oct 2020 03:02:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/alasdair-mcandrew" aria-label="Profile: Alasdair-McAndrew">@<bdi>Alasdair-McAndrew</bdi></a> Hopefully someone will provide the code, but oblique cylinders can easily be created using extrudeLinear().</p>
]]></description><link>https://openjscad.nodebb.com/post/484</link><guid isPermaLink="true">https://openjscad.nodebb.com/post/484</guid><dc:creator><![CDATA[z3dev]]></dc:creator><pubDate>Tue, 20 Oct 2020 03:02:58 GMT</pubDate></item></channel></rss>
