<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Unexpected Holes into volume extruded from Svg paths]]></title><description><![CDATA[<p dir="auto">Hello, I'm trying to make simple volumes made of svg path. I tried to make a full path using Inkscape path difference, but the imported svg contains several paths, the first = background and the others that need to be subtract from it. Anyway, it works, and I obtain a volume, but it contains holes that appear when I try to clean it and make it impossible to work it (I'm trying to create bevels) even after MeshLab removed all non-manifold vertices.<br />
I also tried to export the volume made from only the background extruded, and it already contained holes.</p>
<p dir="auto"><img src="/assets/uploads/files/1604830586027-capture-d-%C3%A9cran-de-2020-11-08-11-09-47.png" alt="Capture d’écran de 2020-11-08 11-09-47.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://openjscad.nodebb.com/topic/194/unexpected-holes-into-volume-extruded-from-svg-paths</link><generator>RSS for Node</generator><lastBuildDate>Mon, 09 Nov 2026 17:10:26 GMT</lastBuildDate><atom:link href="https://openjscad.nodebb.com/topic/194.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 08 Nov 2020 10:38:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Unexpected Holes into volume extruded from Svg paths on Tue, 10 Nov 2020 01:52:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gilboonet" aria-label="Profile: gilboonet">@<bdi>gilboonet</bdi></a> no problem.</p>
<p dir="auto">there's plenty to fix still, but each release improves V2 JSCAD. i'll post an update once there's something to test for this issue.</p>
]]></description><link>https://openjscad.nodebb.com/post/523</link><guid isPermaLink="true">https://openjscad.nodebb.com/post/523</guid><dc:creator><![CDATA[z3dev]]></dc:creator><pubDate>Tue, 10 Nov 2020 01:52:27 GMT</pubDate></item><item><title><![CDATA[Reply to Unexpected Holes into volume extruded from Svg paths on Mon, 09 Nov 2020 08:10:06 GMT]]></title><description><![CDATA[<p dir="auto">Any 3d format could be used. I ran this test because I was mistakenly thinking that the Alpha 11 release would fixed issue #696.</p>
]]></description><link>https://openjscad.nodebb.com/post/522</link><guid isPermaLink="true">https://openjscad.nodebb.com/post/522</guid><dc:creator><![CDATA[gilboonet]]></dc:creator><pubDate>Mon, 09 Nov 2020 08:10:06 GMT</pubDate></item><item><title><![CDATA[Reply to Unexpected Holes into volume extruded from Svg paths on Mon, 09 Nov 2020 03:44:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gilboonet" aria-label="Profile: gilboonet">@<bdi>gilboonet</bdi></a> what's the target export format? STL?</p>
<p dir="auto">this looks like the same issue as discussed in issue #696. the STL export needs an additional step called fixTjunctions(). the current export doesn't guarantee proper meshs with triangles.</p>
<p dir="auto">i'll work on this as a priority for the next release.</p>
]]></description><link>https://openjscad.nodebb.com/post/521</link><guid isPermaLink="true">https://openjscad.nodebb.com/post/521</guid><dc:creator><![CDATA[z3dev]]></dc:creator><pubDate>Mon, 09 Nov 2020 03:44:31 GMT</pubDate></item></channel></rss>
