<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[some feedback]]></title><description><![CDATA[<p dir="auto">Hello, here 2 things that I noticed :</p>
<li>
<p dir="auto">I use a text parameter and i have troubles when typing something on it, it seems to reload default/initial value after each keystroke or something like that, so I cannot type my value and needed to type it somewhere else and copy/paste it.</p>
</li>
<li>
<p dir="auto">I usually color faces of a volume for one of my processes, and I used to export it to .obj with those colors as materials. And when I want to use that .obj with a script regardless of those materials, I union the array that the required("./volume.obj") returns, but then the volume I have seems to have errors. Last one I tested returned 0 for Y measurementBox. I tried ti check this opening the .obj on a script but then it return good value for Y. So for now I'm using two versions of the same .obj, one with separated materials, and another without.<br />
Here is the volume I tested, it is very simple. It's maybe the flat nature of my separated parts that causes union() to fail.<br />
<img src="/assets/uploads/files/1607511803292-capture-d-%C3%A9cran-de-2020-12-09-11-50-31.png" alt="Capture d’écran de 2020-12-09 11-50-31.png" class=" img-fluid img-markdown" /></p>
</li>
]]></description><link>https://openjscad.nodebb.com/topic/206/some-feedback</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 10:05:47 GMT</lastBuildDate><atom:link href="https://openjscad.nodebb.com/topic/206.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 09 Dec 2020 11:06:23 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to some feedback on Thu, 10 Dec 2020 18:00:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/z3dev" aria-label="Profile: z3dev">@<bdi>z3dev</bdi></a> I just tested again in order to write the issue, but apparently there is no more problem with text parameter, it was maybe a problem of cache (I'm using web version).</p>
]]></description><link>https://openjscad.nodebb.com/post/569</link><guid isPermaLink="true">https://openjscad.nodebb.com/post/569</guid><dc:creator><![CDATA[gilboonet]]></dc:creator><pubDate>Thu, 10 Dec 2020 18:00:06 GMT</pubDate></item><item><title><![CDATA[Reply to some feedback on Thu, 10 Dec 2020 07:55:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gilboonet" aria-label="Profile: gilboonet">@<bdi>gilboonet</bdi></a> Thanks for the feedback.</p>
<p dir="auto">The the text parameter issue, please create a new issue. I suspect there's some kind of bug.</p>
<p dir="auto">For the OBJ import issue, can you send the OBJ file to me? <a href="mailto:z3-dev@gfnews.net" rel="nofollow ugc">z3-dev@gfnews.net</a><br />
The design is not that large so I would like to do some tests with the OBJ file.</p>
]]></description><link>https://openjscad.nodebb.com/post/567</link><guid isPermaLink="true">https://openjscad.nodebb.com/post/567</guid><dc:creator><![CDATA[z3dev]]></dc:creator><pubDate>Thu, 10 Dec 2020 07:55:21 GMT</pubDate></item></channel></rss>
