<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Holes when using star primitive with extrusion and boolean operation]]></title><description><![CDATA[<p dir="auto">Hello, I made a little jscad script to make a star using the dedicated primitive, it went well, but unfortunately the model has holes and they appear on all combinations that my script can do :</p>
<li>star + rectangular_extrude</li>
<li>star + rectangular_extrude + linear_extrude + union</li>
<p dir="auto">It might is due to T junction problem.</p>
<p dir="auto"><img src="/assets/uploads/files/1608739302979-capture-d-%C3%A9cran-de-2020-12-23-16-46-47.png" alt="Capture d’écran de 2020-12-23 16-46-47.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://openjscad.nodebb.com/topic/210/holes-when-using-star-primitive-with-extrusion-and-boolean-operation</link><generator>RSS for Node</generator><lastBuildDate>Sun, 06 Sep 2026 17:49:58 GMT</lastBuildDate><atom:link href="https://openjscad.nodebb.com/topic/210.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 23 Dec 2020 16:02:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Holes when using star primitive with extrusion and boolean operation on Wed, 30 Dec 2020 13:42:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/z3dev" aria-label="Profile: z3dev">@<bdi>z3dev</bdi></a> I already tried to use a branch locally but didn't managed to make it work, so I stick to web version at <a href="https://jscad.xyz/" rel="nofollow ugc">https://jscad.xyz/</a></p>
]]></description><link>https://openjscad.nodebb.com/post/588</link><guid isPermaLink="true">https://openjscad.nodebb.com/post/588</guid><dc:creator><![CDATA[gilboonet]]></dc:creator><pubDate>Wed, 30 Dec 2020 13:42:02 GMT</pubDate></item><item><title><![CDATA[Reply to Holes when using star primitive with extrusion and boolean operation on Wed, 30 Dec 2020 07:01:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gilboonet" aria-label="Profile: gilboonet">@<bdi>gilboonet</bdi></a> thanks again.</p>
<p dir="auto">yeah. it looks like a t-junction issue again. if you have the time then please try the V2 branch called ' <a href="https://github.com/jscad/OpenJSCAD.org/pull/743" rel="nofollow ugc">v2-fix-t-junctions</a>', as some feedback on the changes would be good.</p>
]]></description><link>https://openjscad.nodebb.com/post/587</link><guid isPermaLink="true">https://openjscad.nodebb.com/post/587</guid><dc:creator><![CDATA[z3dev]]></dc:creator><pubDate>Wed, 30 Dec 2020 07:01:12 GMT</pubDate></item><item><title><![CDATA[Reply to Holes when using star primitive with extrusion and boolean operation on Tue, 29 Dec 2020 18:29:59 GMT]]></title><description><![CDATA[<p dir="auto">I rewrote it with v1 and the star rendered has no holes. I avoided rectangular_extrude because I wasn't able to use it without roundends. And I need to find a way to compute star width using a % from the outerpath (I form the star polygon with the outerpath minus itself scaled (0.8) for the moment.<br />
<img src="/assets/uploads/files/1609266585573-capture-d-%C3%A9cran-de-2020-12-29-19-15-45.png" alt="Capture d’écran de 2020-12-29 19-15-45.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://openjscad.nodebb.com/post/586</link><guid isPermaLink="true">https://openjscad.nodebb.com/post/586</guid><dc:creator><![CDATA[gilboonet]]></dc:creator><pubDate>Tue, 29 Dec 2020 18:29:59 GMT</pubDate></item></channel></rss>
