<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[V2 Update 2021 Jan 02]]></title><description><![CDATA[<p dir="auto">Please get the latest version of JSCAD V2, as there have been some changes as well as bug fixes.</p>
<p dir="auto">New Features:<br />
<strong>web:</strong> initial implementation of the built-in editor</p>
<p dir="auto">Bug Fixes:<br />
<strong>modeling:</strong> corrected calculation of plane for complex slices<br />
<strong>modeling:</strong> re-implemented poly2.isPointInside to correct issues in expand/offset<br />
<strong>web:</strong> fix instant update<br />
<strong>web:</strong> corrected shortcuts for reloading scripts<br />
<strong>core:</strong> corrected logic of applyParameterDefinitions to retain parameter values when no definition is found</p>
<li>@jscad/cli@2.0.0-alpha.12</li>
<li>@jscad/core@2.0.0-alpha.12</li>
<li>@jscad/amf-deserializer@2.0.0-alpha.9</li>
<li>@jscad/amf-serializer@2.0.0-alpha.10</li>
<li>@jscad/dxf-deserializer@2.0.0-alpha.9</li>
<li>@jscad/dxf-serializer@2.0.0-alpha.9</li>
<li>@jscad/io-utils@2.0.0-alpha.9</li>
<li>@jscad/io@2.0.0-alpha.11</li>
<li>@jscad/json-deserializer@2.0.0-alpha.9</li>
<li>@jscad/json-serializer@2.0.0-alpha.9</li>
<li>@jscad/obj-deserializer@2.0.0-alpha.9</li>
<li>@jscad/stl-deserializer@2.0.0-alpha.10</li>
<li>@jscad/stl-serializer@2.0.0-alpha.9</li>
<li>@jscad/svg-deserializer@2.0.0-alpha.9</li>
<li>@jscad/svg-serializer@2.0.0-alpha.10</li>
<li>@jscad/x3d-serializer@2.0.0-alpha.10</li>
<li>@jscad/modeling@2.0.0-alpha.9</li>
<li>@jscad/regl-renderer@2.0.0-alpha.11</li>
<li>@jscad/vtree@2.0.0-alpha.10</li>
<li>@jscad/web@2.0.0-alpha.14</li>
<p dir="auto"><strong>BIG NOTE: <a href="https://www.jscad.xyz/" rel="nofollow ugc">The V2 website</a> is also using this release.</strong></p>
<p dir="auto">There's <a href="https://www.jscad.xyz/docs/" rel="nofollow ugc">on-line documentation</a> as well for those needing additional information about the modeling API.</p>
<p dir="auto">For those using a local copy of JSCAD V2, be sure to run the following commands.</p>
<pre><code>git pull
npm run clean (and answer Y)
<p dir="auto">Both CLI and WEB UI are usable for creating designs. In the WEB UI, it's best to drag-n-drop project folders to the window, and work with the pieces via a favorite editor. If "Enable auto reload" is checked then changes will be detected, and rendered again.</p>
<p dir="auto">For those wanting to get hold of JSCAD V2, it's still in 'early adoption' mode. But you can <a href="https://openjscad.org/dokuwiki/doku.php?id=early_v2" rel="nofollow ugc">get started here</a>.</p>
<p dir="auto">And a BIG THANKS for everyone that has provided feedback. Keep those comments coming!</p>
<p dir="auto"><strong>Have a great and safe 2021!!!</strong></p>
]]></description><link>https://openjscad.nodebb.com/topic/213/v2-update-2021-jan-02</link><generator>RSS for Node</generator><lastBuildDate>Thu, 13 Aug 2026 15:32:50 GMT</lastBuildDate><atom:link href="https://openjscad.nodebb.com/topic/213.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 02 Jan 2021 04:59:02 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to V2 Update 2021 Jan 02 on Fri, 05 Feb 2021 21:38:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dinther" aria-label="Profile: Dinther">@<bdi>Dinther</bdi></a> said in <a href="/post/661">V2 Update 2021 Jan 02</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/z3dev" aria-label="Profile: z3dev">@<bdi>z3dev</bdi></a> Thanks for that. I have a few thoughts penned down myself and I see gilboonet posted his ideas too.</p>
<p dir="auto">Would it be prudent if I start a new topic called "Sketcher" on the forum?</p>
<p dir="auto">Please. Looking forward to the discussion and ideas.</p>
]]></description><link>https://openjscad.nodebb.com/post/662</link><guid isPermaLink="true">https://openjscad.nodebb.com/post/662</guid><dc:creator><![CDATA[z3dev]]></dc:creator><pubDate>Fri, 05 Feb 2021 21:38:49 GMT</pubDate></item><item><title><![CDATA[Reply to V2 Update 2021 Jan 02 on Fri, 05 Feb 2021 20:59:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/z3dev" aria-label="Profile: z3dev">@<bdi>z3dev</bdi></a> Thanks for that. I have a few thoughts penned down myself and I see gilboonet posted his ideas too.</p>
]]></description><link>https://openjscad.nodebb.com/post/661</link><guid isPermaLink="true">https://openjscad.nodebb.com/post/661</guid><dc:creator><![CDATA[Dinther]]></dc:creator><pubDate>Fri, 05 Feb 2021 20:59:25 GMT</pubDate></item><item><title><![CDATA[Reply to V2 Update 2021 Jan 02 on Fri, 05 Feb 2021 10:58:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dinther" aria-label="Profile: Dinther">@<bdi>Dinther</bdi></a> At a smaller scale than a sketch library, I wrote a little function to make patterns with V1, but only for polygons (mostly regular but also not ones). It is very simple, you drop a polygon, then attach another one to one of its sides and continue as long as needed. Maybe it could help you.<br />
<img src="/assets/uploads/files/1612522419566-capture-d-%C3%A9cran-de-2020-05-24-16-21-10.png" alt="Capture d’écran de 2020-05-24 16-21-10.png" class=" img-fluid img-markdown" /><br />
It can be tested here : <a href="https://openjscad.org/#https://raw.githubusercontent.com/gilboonet/designs/master/make_pattern.jscad" rel="nofollow ugc">https://openjscad.org/#https://raw.githubusercontent.com/gilboonet/designs/master/make_pattern.jscad</a></p>
]]></description><link>https://openjscad.nodebb.com/post/657</link><guid isPermaLink="true">https://openjscad.nodebb.com/post/657</guid><dc:creator><![CDATA[gilboonet]]></dc:creator><pubDate>Fri, 05 Feb 2021 10:58:31 GMT</pubDate></item><item><title><![CDATA[Reply to V2 Update 2021 Jan 02 on Fri, 05 Feb 2021 05:58:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dinther" aria-label="Profile: Dinther">@<bdi>Dinther</bdi></a> Thanks for the nice compliments. <img src="https://openjscad.nodebb.com/assets/plugins/nodebb-plugin-emoji/emoji/android/270c.png?v=552b9a4dc0c" class="not-responsive emoji emoji-android emoji--v" style="height:23px;width:auto;vertical-align:middle" title=":v:" alt="✌" /></p>
<p dir="auto">The path definition module would be a huge enhancement to JSCAD (And discussed often as a future project.) Please let us know when you need some reviews or hands-on testing. And if it fits nicely into the JSCAD API...</p>
<p dir="auto">Here's some thoughts on the subject...</p>
<p dir="auto"><a href="https://github.com/jscad/csg.js/issues/135" rel="nofollow ugc">https://github.com/jscad/csg.js/issues/135</a></p>
]]></description><link>https://openjscad.nodebb.com/post/654</link><guid isPermaLink="true">https://openjscad.nodebb.com/post/654</guid><dc:creator><![CDATA[z3dev]]></dc:creator><pubDate>Fri, 05 Feb 2021 05:58:46 GMT</pubDate></item><item><title><![CDATA[Reply to V2 Update 2021 Jan 02 on Fri, 05 Feb 2021 05:46:41 GMT]]></title><description><![CDATA[<p dir="auto">Thank you so much for pushing this project along. I have spend a lot of time with OpenSCAD and was blown away how much sense it makes to describe parametric models in code.</p>
<p dir="auto">With a solid background in Javascript it makes a lot more sense to code in a known language rather then a new one.</p>
<p dir="auto">I choose it over Fusion360 because I feel much more in control. I am working on a sketch library which will bring quick path definition to jsCAD similar to how path works in SVG but a little fancier.</p>
]]></description><link>https://openjscad.nodebb.com/post/653</link><guid isPermaLink="true">https://openjscad.nodebb.com/post/653</guid><dc:creator><![CDATA[Dinther]]></dc:creator><pubDate>Fri, 05 Feb 2021 05:46:41 GMT</pubDate></item><item><title><![CDATA[Reply to V2 Update 2021 Jan 02 on Mon, 04 Jan 2021 21:31:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wolfgangfahl" aria-label="Profile: WolfgangFahl">@<bdi>WolfgangFahl</bdi></a> V2 Web is at <a href="https://jscad.xyz/" rel="nofollow ugc">https://jscad.xyz/</a></p>
]]></description><link>https://openjscad.nodebb.com/post/601</link><guid isPermaLink="true">https://openjscad.nodebb.com/post/601</guid><dc:creator><![CDATA[gilboonet]]></dc:creator><pubDate>Mon, 04 Jan 2021 21:31:46 GMT</pubDate></item><item><title><![CDATA[Reply to V2 Update 2021 Jan 02 on Mon, 04 Jan 2021 16:52:29 GMT]]></title><description><![CDATA[<p dir="auto">I have never seen or used v2 yet. It it avaiable online somewhere? It would be great if <a href="https://www.openjscad.org/" rel="nofollow ugc">https://www.openjscad.org/</a> would have a v2 link and especially a simple switch to see the same code in v1/v2.</p>
]]></description><link>https://openjscad.nodebb.com/post/600</link><guid isPermaLink="true">https://openjscad.nodebb.com/post/600</guid><dc:creator><![CDATA[WolfgangFahl]]></dc:creator><pubDate>Mon, 04 Jan 2021 16:52:29 GMT</pubDate></item><item><title><![CDATA[Reply to V2 Update 2021 Jan 02 on Sun, 03 Jan 2021 10:16:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/z3dev" aria-label="Profile: z3dev">@<bdi>z3dev</bdi></a> Here is what I have with my 4K screen :<br />
<img src="/assets/uploads/files/1609667824411-capture-d-%C3%A9cran-de-2021-01-03-10-55-01-resized.png" alt="Capture d’écran de 2021-01-03 10-55-01.png" class=" img-fluid img-markdown" /><br />
It might be useful to be able to reduce editor width, here it could easily be three times narrower, but at the same time it would be nice to be able to have a bigger font size (using navigator zoom would do that but also for parameters and render). Code folding would be a great addition, and the pinnacle that I'm looking for for a long time would be multi-column, but there's very little chance for that. There's no need for search/replace as navigator already provide them.</p>
]]></description><link>https://openjscad.nodebb.com/post/598</link><guid isPermaLink="true">https://openjscad.nodebb.com/post/598</guid><dc:creator><![CDATA[gilboonet]]></dc:creator><pubDate>Sun, 03 Jan 2021 10:16:00 GMT</pubDate></item><item><title><![CDATA[Reply to V2 Update 2021 Jan 02 on Sun, 03 Jan 2021 04:23:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gilboonet" aria-label="Profile: gilboonet">@<bdi>gilboonet</bdi></a> Thanks for the nice comments on the release.</p>
<p dir="auto">Any feedback on the editor is welcome. The editor is based on <a href="https://codemirror.net/" rel="nofollow ugc">CodeMirror</a> which has a huge number of options, themes, etc.</p>
]]></description><link>https://openjscad.nodebb.com/post/596</link><guid isPermaLink="true">https://openjscad.nodebb.com/post/596</guid><dc:creator><![CDATA[z3dev]]></dc:creator><pubDate>Sun, 03 Jan 2021 04:23:15 GMT</pubDate></item><item><title><![CDATA[Reply to V2 Update 2021 Jan 02 on Sat, 02 Jan 2021 17:25:06 GMT]]></title><description><![CDATA[<p dir="auto">I made a very simple 7 segments display script that uses union and if it still has holes when exported to wings 3d, it is the first time that those holes are easy to repair using only wings3d option for that (body mode, select the model, face mode, right click, select hole option, right click)<br />
<img src="/assets/uploads/files/1609608185645-capture-d-%C3%A9cran-de-2021-01-02-18-17-30.png" alt="Capture d’écran de 2021-01-02 18-17-30.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://openjscad.nodebb.com/post/592</link><guid isPermaLink="true">https://openjscad.nodebb.com/post/592</guid><dc:creator><![CDATA[gilboonet]]></dc:creator><pubDate>Sat, 02 Jan 2021 17:25:06 GMT</pubDate></item><item><title><![CDATA[Reply to V2 Update 2021 Jan 02 on Sat, 02 Jan 2021 16:53:11 GMT]]></title><description><![CDATA[<p dir="auto">Thanks a lot, that's very nice to have this built-in editor. I was already accustomed to use my external editor, but to explain to non IT specialist users how to use jscad, it is nice to have it as simple as possible.</p>
<p dir="auto"><img src="/assets/uploads/files/1609606140578-capture-d-%C3%A9cran-de-2021-01-02-17-48-19.png" alt="Capture d’écran de 2021-01-02 17-48-19.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://openjscad.nodebb.com/post/591</link><guid isPermaLink="true">https://openjscad.nodebb.com/post/591</guid><dc:creator><![CDATA[gilboonet]]></dc:creator><pubDate>Sat, 02 Jan 2021 16:53:11 GMT</pubDate></item></channel></rss>
