<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[A questions about project()]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/z3dev" aria-label="Profile: z3dev">@<bdi>z3dev</bdi></a><br />
When I use <code>project()</code> to try to project the <code>.stl</code> model onto a 2d plane, the console prompts:<br />
<img src="/assets/uploads/files/1632723496579-%E6%88%AA%E5%B1%8F2021-09-27-%E4%B8%8B%E5%8D%882.18.08.png" alt="截屏2021-09-27 下午2.18.08.png" class=" img-fluid img-markdown" /><br />
But the 3d model can be displayed normally.</p>
<p dir="auto">This problem does not appear in all <code>.stl</code> models, only complex <code>.stl</code> models will appear in this problem.</p>
<p dir="auto">I debugged and found that the cause of this problem was that <code>poly3.toPoints()</code> returned an empty array.<br />
<img src="/assets/uploads/files/1632724962727-60f9aa8e-2aea-4f4f-8f7a-72975d45abc5-image.png" alt="60f9aa8e-2aea-4f4f-8f7a-72975d45abc5-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Should the empty array be filtered before calling <code>poly3.toPoints()</code>？</p>
]]></description><link>https://openjscad.nodebb.com/topic/304/a-questions-about-project</link><generator>RSS for Node</generator><lastBuildDate>Sun, 18 Oct 2026 00:13:59 GMT</lastBuildDate><atom:link href="https://openjscad.nodebb.com/topic/304.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 27 Sep 2021 06:19:09 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to A questions about project() on Mon, 27 Sep 2021 09:15:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/z3dev" aria-label="Profile: z3dev">@<bdi>z3dev</bdi></a><br />
Ok, I have submitted an issue on github.<br />
<a href="https://github.com/jscad/OpenJSCAD.org/issues/916" rel="nofollow ugc">https://github.com/jscad/OpenJSCAD.org/issues/916</a></p>
]]></description><link>https://openjscad.nodebb.com/post/921</link><guid isPermaLink="true">https://openjscad.nodebb.com/post/921</guid><dc:creator><![CDATA[jess yan]]></dc:creator><pubDate>Mon, 27 Sep 2021 09:15:53 GMT</pubDate></item><item><title><![CDATA[Reply to A questions about project() on Mon, 27 Sep 2021 08:32:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jess-yan" aria-label="Profile: jess-yan">@<bdi>jess-yan</bdi></a> this could be a bug, but again many STL meshes are full of holes and incomplete.</p>
<p dir="auto">It would be best to open a new issue at GitHub. And attach one of those ‘bad’ STL files.</p>
]]></description><link>https://openjscad.nodebb.com/post/920</link><guid isPermaLink="true">https://openjscad.nodebb.com/post/920</guid><dc:creator><![CDATA[z3dev]]></dc:creator><pubDate>Mon, 27 Sep 2021 08:32:57 GMT</pubDate></item></channel></rss>
