<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Build a specialized graphical editor]]></title><description><![CDATA[<p dir="auto">Hello, years ago I made an editor that used pre V1 JSCAD to help me build structures and I'm wondering whether it is now possible to do the same using V2 JSCAD.</p>
<p dir="auto">This editor is a little like a polyhedron editor except that there's no control on Z axis. The structure consist of a net of shelves using a common array of vertices, so that when a vertice is moved, it also moves all shelves that are using it.</p>
<p dir="auto"><img src="/assets/uploads/files/1649938856608-capture-d-%C3%A9cran-de-2022-04-14-14-08-35.png" alt="Capture d’écran de 2022-04-14 14-08-35.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">The editor is made of a JSCAD script that uses an hidden parameter and a js/html UI where the vertices and the shelves are created and moved, synced to the hidden JSCAD paramter. Rendering is done by clicking "Update" on JSCAD UI. I also added load/save of data (vertices and shelves).</p>
<p dir="auto">Do you have an entry point I can use to do the same using V2 JSCAD ?</p>
<p dir="auto">At least I could try to make a simpler JSCAD script that loads a data file, but how can I achieve this ? Using require ? or JSON ?</p>
<p dir="auto">The editor is here : <a href="http://gilboo.carton.free.fr/OJSC5/edit_ner2.html" rel="nofollow ugc">http://gilboo.carton.free.fr/OJSC5/edit_ner2.html</a></p>
]]></description><link>https://openjscad.nodebb.com/topic/358/build-a-specialized-graphical-editor</link><generator>RSS for Node</generator><lastBuildDate>Wed, 14 Oct 2026 16:08:04 GMT</lastBuildDate><atom:link href="https://openjscad.nodebb.com/topic/358.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 14 Apr 2022 12:30:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Build a specialized graphical editor on Fri, 15 Apr 2022 06:27:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hrgdavor" aria-label="Profile: hrgdavor">@<bdi>hrgdavor</bdi></a> Thank you, I will try from this demo.html file. I already used that file at early stage of V2 to take snapshots of a scene to create an animation, but I'm not sure I understood it all.</p>
]]></description><link>https://openjscad.nodebb.com/post/1166</link><guid isPermaLink="true">https://openjscad.nodebb.com/post/1166</guid><dc:creator><![CDATA[gilboonet]]></dc:creator><pubDate>Fri, 15 Apr 2022 06:27:31 GMT</pubDate></item><item><title><![CDATA[Reply to Build a specialized graphical editor on Thu, 14 Apr 2022 13:29:48 GMT]]></title><description><![CDATA[<p dir="auto">for now best piece of code to start with using jscad standalone or creating an app is I think in <code>packages/utils/regl-renderer/demo.html</code></p>
<p dir="auto">it is the basis I used for my jscad experiments</p>
]]></description><link>https://openjscad.nodebb.com/post/1164</link><guid isPermaLink="true">https://openjscad.nodebb.com/post/1164</guid><dc:creator><![CDATA[hrgdavor]]></dc:creator><pubDate>Thu, 14 Apr 2022 13:29:48 GMT</pubDate></item></channel></rss>
