<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Rectangle with multiple style corner]]></title><description><![CDATA[<p dir="auto">Hello everybody,</p>
<p dir="auto">can I create a rectangle with multiple style corner.<br />
Example :</p>
<li>2 edge corners</li>
<li>1 round corners</li>
<li>1 chamfer corner</li>
<p dir="auto">I don't found the solution. I just possibility to create that with line + arc...</p>
<p dir="auto">Thanks</p>
]]></description><link>https://openjscad.nodebb.com/topic/361/rectangle-with-multiple-style-corner</link><generator>RSS for Node</generator><lastBuildDate>Sun, 15 Mar 2026 05:24:45 GMT</lastBuildDate><atom:link href="https://openjscad.nodebb.com/topic/361.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 13 May 2022 12:09:16 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Rectangle with multiple style corner on Mon, 16 May 2022 11:44:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://openjscad.nodebb.com/uid/1">@z3dev</a> ok, thank you very much for your feedback</p>
]]></description><link>https://openjscad.nodebb.com/post/1183</link><guid isPermaLink="true">https://openjscad.nodebb.com/post/1183</guid><dc:creator><![CDATA[Antoine Guillaume]]></dc:creator><pubDate>Mon, 16 May 2022 11:44:21 GMT</pubDate></item><item><title><![CDATA[Reply to Rectangle with multiple style corner on Fri, 13 May 2022 23:12:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://openjscad.nodebb.com/uid/748">@antoine-guillaume</a> welcome</p>
<p dir="auto">You will have to assemble the special shape from lines and arcs. You can look at the code for rounded rectangle for some inspiration.</p>
<p dir="auto"><a href="https://github.com/jscad/OpenJSCAD.org/blob/master/packages/modeling/src/primitives/roundedRectangle.js" rel="nofollow ugc">https://github.com/jscad/OpenJSCAD.org/blob/master/packages/modeling/src/primitives/roundedRectangle.js</a></p>
]]></description><link>https://openjscad.nodebb.com/post/1181</link><guid isPermaLink="true">https://openjscad.nodebb.com/post/1181</guid><dc:creator><![CDATA[z3dev]]></dc:creator><pubDate>Fri, 13 May 2022 23:12:36 GMT</pubDate></item></channel></rss>
