<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Release : 2022 AUG 21]]></title><description><![CDATA[<h3>Release : 2022 AUG 21</h3>
<p dir="auto">There's a new release of JSCAD, including changes from several pull requests.</p>
<p dir="auto"><strong>Welcome TAU!</strong></p>
<p dir="auto">TAU is the true constant for relating the circumference of a circle to its linear dimension.<br />
Equivalent to PI*2. You will now find TAU throughout the code base, and mentioned in documentation.<br />
We believe TAU will make rotations simple to understand.</p>
<p dir="auto">EXAMPLE</p>
<pre><code>const { TAU } = require('@jscad/modeling').maths.constants
const { cube } = require('@jscad/modeling').primitives
const { rotate } = require('@jscad/modeling').transforms
const main = () =&gt; {
  const shape = rotate([TAU/4, TAU*0.75, TAU/24], cube({}))
  return shape
module.exports = {
  main
<p dir="auto">For even more information about TAU, see <a href="https://tauday.com/tau-manifesto" rel="nofollow ugc">The Tau Manifesto</a></p>
<h4>Features</h4>
<li><strong>modeling:</strong> added TAU constant to maths, and refactored code and documentation</li>
<li><strong>web:</strong> added chinese translations to desktop/locales and web/locales</li>
<li><strong>modeling:</strong> added TS definitions for modifiers</li>
<p dir="auto">Thanks to @jobinson99  for the Chinese translations for the website.</p>
<li>@jscad/cli@2.2.23</li>
<li>@jscad/core@2.6.3</li>
<li>@jscad/3mf-serializer@2.1.6</li>
<li>@jscad/amf-deserializer@2.3.2</li>
<li>@jscad/amf-serializer@2.1.12</li>
<li>@jscad/dxf-deserializer@2.3.19</li>
<li>@jscad/dxf-serializer@2.1.12</li>
<li>@jscad/io-utils@2.0.22</li>
<li>@jscad/io@2.4.2</li>
<li>@jscad/json-deserializer@2.0.23</li>
<li>@jscad/json-serializer@2.0.22</li>
<li>@jscad/obj-deserializer@2.0.22</li>
<li>@jscad/obj-serializer@2.1.12</li>
<li>@jscad/stl-deserializer@2.1.19</li>
<li>@jscad/stl-serializer@2.1.12</li>
<li>@jscad/svg-deserializer@2.5.2</li>
<li>@jscad/svg-serializer@2.3.10</li>
<li>@jscad/x3d-deserializer@2.2.2</li>
<li>@jscad/x3d-serializer@2.4.2</li>
<li>@jscad/modeling@2.10.0</li>
<li>@jscad/regl-renderer@2.6.3</li>
<li>@jscad/vtree@2.0.23</li>
<li>@jscad/web@2.6.0</li>
<p dir="auto">lerna success published 23 packages</p>
]]></description><link>https://openjscad.nodebb.com/topic/381/release-2022-aug-21</link><generator>RSS for Node</generator><lastBuildDate>Wed, 18 Nov 2026 05:52:10 GMT</lastBuildDate><atom:link href="https://openjscad.nodebb.com/topic/381.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 21 Aug 2022 02:56:24 GMT</pubDate><ttl>60</ttl></channel></rss>
