<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[can not import c:/jscad/whatever.stl on windows]]></title><description><![CDATA[<p dir="auto">from the website I can not import the stl, I saved.</p>
<p dir="auto">I consistently get the message:</p>
<p dir="auto"><code>Error: Cannot find relative path to module /jscad</code></p>
<p dir="auto">I am on WIN10</p>
]]></description><link>https://openjscad.nodebb.com/topic/417/can-not-import-c-jscad-whatever-stl-on-windows</link><generator>RSS for Node</generator><lastBuildDate>Sun, 18 Oct 2026 01:12:39 GMT</lastBuildDate><atom:link href="https://openjscad.nodebb.com/topic/417.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 24 Dec 2023 09:50:56 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to can not import c:/jscad/whatever.stl on windows on Sun, 31 Dec 2023 19:15:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hrgdavor" aria-label="Profile: hrgdavor">@<bdi>hrgdavor</bdi></a>  I have not tried project folder drag-and-drop into the web app.  Will do.</p>
<p dir="auto">Thanks</p>
]]></description><link>https://openjscad.nodebb.com/post/1384</link><guid isPermaLink="true">https://openjscad.nodebb.com/post/1384</guid><dc:creator><![CDATA[DBJDBJ]]></dc:creator><pubDate>Sun, 31 Dec 2023 19:15:42 GMT</pubDate></item><item><title><![CDATA[Reply to can not import c:/jscad/whatever.stl on windows on Wed, 27 Dec 2023 22:13:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dbjdbj" aria-label="Profile: DBJDBJ">@<bdi>DBJDBJ</bdi></a> did you try to drag and drop the folder onto the website instead ?</p>
<p dir="auto">I tried the example from jscad repo: packages\examples\import\STLImport<br />
<a href="https://github.com/jscad/OpenJSCAD.org/tree/master/packages/examples/import/STLImport" rel="nofollow ugc">https://github.com/jscad/OpenJSCAD.org/tree/master/packages/examples/import/STLImport</a></p>
<p dir="auto">I used the folder from the checked out code</p>
<p dir="auto">and it worked with the button and with drag and drop.</p>
<p dir="auto">Can you provide a link to zip file with the failing project?</p>
]]></description><link>https://openjscad.nodebb.com/post/1383</link><guid isPermaLink="true">https://openjscad.nodebb.com/post/1383</guid><dc:creator><![CDATA[hrgdavor]]></dc:creator><pubDate>Wed, 27 Dec 2023 22:13:02 GMT</pubDate></item><item><title><![CDATA[Reply to can not import c:/jscad/whatever.stl on windows on Mon, 25 Dec 2023 09:37:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/z3dev" aria-label="Profile: z3dev">@<bdi>z3dev</bdi></a>   then I used  STLImport example and added my <code>f_.stl</code>.</p>
<pre><code class="language-javascript">const frog = require('./frog.stl')
const sculpture = require('./sculpture.stl')
const f_ = require('./f_.stl')
const main = () =&gt; [ frog ];
module.exports = { main }
<p dir="auto">And ... just <code>f_.stl</code> does not work. The message is either some syntax error or relative path or it says 'processing, please wait' and stays like that ...</p>
<p dir="auto">same <code>f_.stl</code> I can import it into Free CAD and see it over there.</p>
<p dir="auto">But, anyhow it seems I can not "just" upload stl and proceed on top of it, using JSCAD?</p>
]]></description><link>https://openjscad.nodebb.com/post/1382</link><guid isPermaLink="true">https://openjscad.nodebb.com/post/1382</guid><dc:creator><![CDATA[DBJDBJ]]></dc:creator><pubDate>Mon, 25 Dec 2023 09:37:12 GMT</pubDate></item><item><title><![CDATA[Reply to can not import c:/jscad/whatever.stl on windows on Sun, 24 Dec 2023 12:37:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/z3dev" aria-label="Profile: z3dev">@<bdi>z3dev</bdi></a>  just installed local (through git) (also there is no index.html but demo.html) but to no avail. Same issue.</p>
]]></description><link>https://openjscad.nodebb.com/post/1381</link><guid isPermaLink="true">https://openjscad.nodebb.com/post/1381</guid><dc:creator><![CDATA[DBJDBJ]]></dc:creator><pubDate>Sun, 24 Dec 2023 12:37:22 GMT</pubDate></item><item><title><![CDATA[Reply to can not import c:/jscad/whatever.stl on windows on Sun, 24 Dec 2023 12:13:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/z3dev" aria-label="Profile: z3dev">@<bdi>z3dev</bdi></a>  I just went to online, and struggled out  some simple scene (after 3 decades of 3d pause) and dutifully saved _changes (N).stl, as I went along.</p>
<p dir="auto">This morning I got these errors after clicking on a "Load a JSCAD Project" and selecting the folder ...</p>
<p dir="auto">I have not seen JSCAD before until yesterday.</p>
<p dir="auto">Please advise</p>
]]></description><link>https://openjscad.nodebb.com/post/1380</link><guid isPermaLink="true">https://openjscad.nodebb.com/post/1380</guid><dc:creator><![CDATA[DBJDBJ]]></dc:creator><pubDate>Sun, 24 Dec 2023 12:13:21 GMT</pubDate></item><item><title><![CDATA[Reply to can not import c:/jscad/whatever.stl on windows on Sun, 24 Dec 2023 11:16:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dbjdbj" aria-label="Profile: DBJDBJ">@<bdi>DBJDBJ</bdi></a> Welcome!</p>
<p dir="auto">From the message, it seems that you are using a 'project' which contains the STL file. Is that correct?</p>
]]></description><link>https://openjscad.nodebb.com/post/1379</link><guid isPermaLink="true">https://openjscad.nodebb.com/post/1379</guid><dc:creator><![CDATA[z3dev]]></dc:creator><pubDate>Sun, 24 Dec 2023 11:16:30 GMT</pubDate></item></channel></rss>
