<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Load DXF]]></title><description><![CDATA[<p dir="auto">Hi all,<br />
i tried the demo app, but i cannot find the way to upload a dxf file.<br />
Can anyone pinpoint me on the right direction?</p>
<p dir="auto">thanks in advance</p>
]]></description><link>https://openjscad.nodebb.com/topic/420/load-dxf</link><generator>RSS for Node</generator><lastBuildDate>Mon, 07 Sep 2026 02:57:47 GMT</lastBuildDate><atom:link href="https://openjscad.nodebb.com/topic/420.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 08 Feb 2024 16:38:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Load DXF on Sat, 10 Feb 2024 01:21:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lucanitti" aria-label="Profile: LucaNitti">@<bdi>LucaNitti</bdi></a> Welcome!</p>
<p dir="auto">There are a couple of ways to use DXF files. You can convert the DXF to another format, like SVG. Or you can import the DXF, and use the shapes to create different designs.</p>
<p dir="auto">You can convert using the JSCAD CLI command.</p>
<p dir="auto">If you want to use the shapes from the DXF file in designs then a project is required.</p>
<p dir="auto"><a href="https://openjscad.xyz/dokuwiki/doku.php?id=en:design_guide_projects" rel="nofollow ugc">https://openjscad.xyz/dokuwiki/doku.php?id=en:design_guide_projects</a></p>
]]></description><link>https://openjscad.nodebb.com/post/1394</link><guid isPermaLink="true">https://openjscad.nodebb.com/post/1394</guid><dc:creator><![CDATA[z3dev]]></dc:creator><pubDate>Sat, 10 Feb 2024 01:21:08 GMT</pubDate></item></channel></rss>
