<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Release : 2024 FEB 18]]></title><description><![CDATA[<h2>Release : 2024 FEB 18</h2>
<p dir="auto">There's a new release of JSCAD V2, including changes from several pull requests.</p>
<li><strong>svg-serializer:</strong> fix conversion of alpha colors to SVG RGBA opacity</li>
<li><strong>x3d-deserializer:</strong> corrected to accept commas as MF value delimiters</li>
<li><strong>modeling:</strong> added fromNoisyPoints() to plane</li>
<li><strong>modeling:</strong> added orientation option to polygon</li>
<li><strong>modeling:</strong> corrected geom2 mirroring transform</li>
<li><strong>regl-renderer:</strong> define the entity type and corrected TS definitions</li>
<p dir="auto">THANKS to @btakita for the fix to the SVG serialier<br />
THANKS to @andreasplesch for the fixes to the X3D deserialier<br />
THANKS to @platypil for the geom2 fixes<br />
THANKS to @bruceborrett for the new TS definitions</p>
<li>@jscad/cli@2.3.1</li>
<li>@jscad/core@2.6.8</li>
<li>@jscad/3mf-serializer@2.1.10</li>
<li>@jscad/amf-deserializer@2.3.6</li>
<li>@jscad/amf-serializer@2.1.16</li>
<li>@jscad/dxf-deserializer@2.3.23</li>
<li>@jscad/dxf-serializer@2.1.16</li>
<li>@jscad/io-utils@2.0.26</li>
<li>@jscad/io@2.4.7</li>
<li>@jscad/json-deserializer@2.0.27</li>
<li>@jscad/json-serializer@2.0.26</li>
<li>@jscad/obj-deserializer@2.0.26</li>
<li>@jscad/obj-serializer@2.1.16</li>
<li>@jscad/stl-deserializer@2.1.23</li>
<li>@jscad/stl-serializer@2.1.16</li>
<li>@jscad/svg-deserializer@2.5.7</li>
<li>@jscad/svg-serializer@2.3.14</li>
<li>@jscad/x3d-deserializer@2.2.6</li>
<li>@jscad/x3d-serializer@2.4.6</li>
<li>@jscad/modeling@2.12.1</li>
<li>@jscad/regl-renderer@2.6.8</li>
<li>@jscad/vtree@2.0.27</li>
<li>@jscad/web@2.6.6</li>
<p dir="auto">lerna success published 23 packages</p>
]]></description><link>https://openjscad.nodebb.com/topic/422/release-2024-feb-18</link><generator>RSS for Node</generator><lastBuildDate>Mon, 20 Apr 2026 21:28:17 GMT</lastBuildDate><atom:link href="https://openjscad.nodebb.com/topic/422.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 18 Feb 2024 02:31:20 GMT</pubDate><ttl>60</ttl></channel></rss>
