<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[JSCAD Release V3 Alpha : 2026 JAN 18]]></title><description><![CDATA[<p dir="auto">There's a new release of JSCAD V3 Alpha, including changes from several V3 pull requests.</p>
<p dir="auto">NOTE: For CLI users, please see the new command line options.</p>
<p dir="auto">Bug Fixes</p>
<li>cli: corrected the loading of modules on Windows</li>
<li>x3d-deserializer: small change in source output due to changes in geom3</li>
<p dir="auto">Features</p>
<li>cli: reworked command line parameter parsing to use commander</li>
<li>modeling: geom3 renamed fromVertices and toVertices</li>
<li>modeling: new geometry for 3D paths (path3)</li>
<li>modeling: removed compact binary support</li>
<p dir="auto">BIG Thanks to @NemoStein for the changes to the CLI in support of Windows installations.</p>
<p dir="auto">@jscad/3mf-deserializer@3.0.3-alpha.0<br />
@jscad/3mf-serializer@3.0.3-alpha.0<br />
@jscad/cli@3.0.3-alpha.0<br />
@jscad/core@3.0.3-alpha.0<br />
@jscad/dxf-deserializer@3.0.3-alpha.0<br />
@jscad/dxf-serializer@3.0.3-alpha.0<br />
@jscad/io@3.0.3-alpha.0<br />
@jscad/io-utils@3.0.3-alpha.0<br />
@jscad/json-deserializer@3.0.3-alpha.0<br />
@jscad/json-serializer@3.0.3-alpha.0<br />
@jscad/modeling@3.0.3-alpha.0<br />
@jscad/obj-deserializer@3.0.3-alpha.0<br />
@jscad/obj-serializer@3.0.3-alpha.0<br />
@jscad/regl-renderer@3.0.3-alpha.0<br />
@jscad/stl-deserializer@3.0.3-alpha.0<br />
@jscad/stl-serializer@3.0.3-alpha.0<br />
@jscad/svg-deserializer@3.0.3-alpha.0<br />
@jscad/svg-serializer@3.0.3-alpha.0<br />
@jscad/x3d-deserializer@3.0.3-alpha.0<br />
@jscad/x3d-serializer@3.0.3-alpha.0</p>
<p dir="auto">lerna-lite success published 20 packages</p>
]]></description><link>https://openjscad.nodebb.com/topic/448/jscad-release-v3-alpha-2026-jan-18</link><generator>RSS for Node</generator><lastBuildDate>Thu, 13 Aug 2026 15:36:24 GMT</lastBuildDate><atom:link href="https://openjscad.nodebb.com/topic/448.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 19 Jan 2026 12:14:07 GMT</pubDate><ttl>60</ttl></channel></rss>
