<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[JSCAD Release V3 Alpha : 2026 NOV 07]]></title><description><![CDATA[<h2>JSCAD Release V3 Alpha : 2026 NOV 07</h2>
<p dir="auto">There's a new release of JSCAD V3 Alpha, including changes from several pull requests.</p>
<p dir="auto">NOTE: For CLI users, please see the new command line options.</p>
<h3>Bug Fixes</h3>
<li><strong>modeling:</strong> added sagitta calculation</li>
<li><strong>modeling:</strong> corrected extrudeHelical options to use segments</li>
<li><strong>modeling:</strong> corrected geom2 reverse to retain color</li>
<li><strong>modeling:</strong> corrected geom3 invert to retain color</li>
<li><strong>modeling:</strong> corrected path3 reverse to retain color</li>
<li><strong>modeling:</strong> corrected slice reverse to retain color</li>
<li><strong>modeling:</strong> sync fixes from martinez</li>
<li>@jscad/3mf-deserializer@3.0.8-alpha.0</li>
<li>@jscad/3mf-serializer@3.0.8-alpha.0</li>
<li>@jscad/cli@3.0.8-alpha.0</li>
<li>@jscad/core@3.0.8-alpha.0</li>
<li>@jscad/dxf-deserializer@3.0.8-alpha.0</li>
<li>@jscad/dxf-serializer@3.0.8-alpha.0</li>
<li>@jscad/io@3.0.8-alpha.0</li>
<li>@jscad/io-utils@3.0.8-alpha.0</li>
<li>@jscad/json-deserializer@3.0.8-alpha.0</li>
<li>@jscad/json-serializer@3.0.8-alpha.0</li>
<li>@jscad/modeling@3.0.8-alpha.0</li>
<li>@jscad/obj-deserializer@3.0.8-alpha.0</li>
<li>@jscad/obj-serializer@3.0.8-alpha.0</li>
<li>@jscad/regl-renderer@3.0.8-alpha.0</li>
<li>@jscad/stl-deserializer@3.0.8-alpha.0</li>
<li>@jscad/stl-serializer@3.0.8-alpha.0</li>
<li>@jscad/svg-deserializer@3.0.8-alpha.0</li>
<li>@jscad/svg-serializer@3.0.8-alpha.0</li>
<li>@jscad/x3d-deserializer@3.0.8-alpha.0</li>
<li>@jscad/x3d-serializer@3.0.8-alpha.0</li>
<p dir="auto">lerna-lite success published 20 packages</p>
]]></description><link>https://openjscad.nodebb.com/topic/462/jscad-release-v3-alpha-2026-nov-07</link><generator>RSS for Node</generator><lastBuildDate>Sat, 07 Nov 2026 16:09:13 GMT</lastBuildDate><atom:link href="https://openjscad.nodebb.com/topic/462.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 07 Nov 2026 06:00:21 GMT</pubDate><ttl>60</ttl></channel></rss>
