    Scheduled Pinned Locked Moved Archives (Google+)
    1 Posts 1 Posters 1.2k Views 1 Watching
      Alejandro Silvestri
      Someone looking for generate G-Code?
      Someone intereted in its development?
      5 comments
      5
      one plus one
      1
      no shares
      Shared publicly•View activity
      Alejandro Silvestri
      +Сергей Шатунов , I think I can help.
      Let's talk a little more about this.
      I'm familiar with mill: it has a vartical cilyndrical tool, only matters the diameter, so the toolpath will spare the radius from the edge.
      As you can apreciate, english's not my first language. It's my last language 🙂
      Mar 22, 2015
      Alejandro Silvestri
      There are many strategies for toolpaths. Mainly two: you can follow contours on planes XY, or you can follow profiles, the contours on planes XZ or YZ.
      Mar 22, 2015
      Alejandro Silvestri
      Is there a way to "emboss" bodies? If we can inflate bodies 2mm in XY planes, we can get directly the toolpath for 4mm mill.
      Mar 22, 2015
      Alejandro Silvestri
      +Сергей Шатунов , I wrote you to that address, it seems it isn't working.
      I'm thinking on sliding the solid to get a thick slide, as thick as the tool's diameter. I get the slide buy cutting the solid with the two sides planes:
      var slide = solid.cutByPlane(plane1)
      .cutByPlane(plane2.flipped());
      var shape = slide
      .projectToOrthoNormalBasis();
      var path = shape.getOulinePath();
      Mar 30, 2015
      Jeff Gay
      Moderator
      There's import of Gcode in openscad.js which may be helpful.
