    2D union/subtract/intersect to create mesh
    3 Posts 2 Posters 1.2k Views 2 Watching
    • jihyelee-codeJ Offline
      jihyelee-code
      I am trying to union/subtract/intersect two simple polygons.
      I've found how to do it from CAG.
      But I would like to get points as counter clock wise.
      The result using CAG functionality, I could get counter clock wise direction line drawing points, but what I like to get is counter clock wise points order.
      Is there anyway that I can get it?
      It would be fine also if I can use CSG functioinality.
      Thank you.
        gilboonet @jihyelee-code
        @jihyelee-code Did you try with yourPoints.reverse() ?
        jihyelee-codeJ 1 Reply Last reply Reply Quote 0
          jihyelee-code @gilboonet
          @gilboonet Well, actually I figured out! I was using earcut.js to create indice, and with little bit of touch with the result of CAG union/subtract/intersect it worked well. Thanks for the reply.
