Oct 14, 2017
Christian Brunschen
Hi all,
I'm trying to use CSG.ConnectorList but having mixed success. A simple example likefunction main() {
var cs = new CSG.ConnectorList();
cs.appendConnector(
new CSG.Connector([0,0,0], [0,0,1], [1,0,0]));
cs.appendConnector(
new CSG.Connector([0,0,12], [0,0,1], [1,0,0]))
return cs.followWith(CAG.circle({center:[0,0], radius:5,}));
}works fine when entered into https://openjscad.org/ , but when I run OpenJSCAD locally, I get "TypeError: CSG.ConnectorList is not a constructor" .
OpenJSCAD.org
Editor. Render Code, F5 or SHIFT + Return. Save To Cache, CTRL + S. Load From Cache, CTRL + L. Download Code, CTRL + SHIFT + S. Reset View, CRTL + Return. 3D View. Rotate XZ, Left Mouse. Pan, Middle Mouse or SHIFT + Left Mouse. Rotate XY, Right Mouse or ALT + Left Mouse. Zoom In/Out ...
openjscad.org
7 comments
7
no plus ones
no shares
Shared publiclyChristian Brunschen +Mark Moissette, I was referring to running a local web server, serving the contents of the openjscad.org - OpenJSCAD.org github repository, per the instructions: "Use within a Web Site (pre built files) cd base-directory-of-website git clone https://github.com/jscad/OpenJSCAD.org cd OpenJSCAD.org <start a web server here>" OpenJSCAD.org openjscad.orgOct 16, 2017
Jeff Gay
Moderator
Will definitely try this but there shouldn't be any differences in your local copy versus openjscad.org.If you have any other information then please let us know.
Oct 16, 2017
Christian Brunschen
I just did a fresh sequence of:git clone github.com - jscad/OpenJSCAD.org
cd OpenJSCAD.org
python -m SimpleHTTPServer 8001pointed a web browser (Google Chrome, version Version 61.0.3163.100) at
which reports version "1.0.3"; I pasted in the code above and reproduced the error, "TypeError: CSG.ConnectorList is not a constructor".
I also pointed the same browser at https://openjscad.org/ which reports version "OpenJSCAD.org 1.0.1", pasted the exact same code, and there is worked.
I took screenshots of each: https://imgur.com/a/gBJr7
jscad/OpenJSCAD.org
jscad/OpenJSCAD.org
github.comOct 17, 2017
Christian Brunschen
Thank you!Oct 17, 2017
Christian Brunschen
Done (with some copy-pasting from this thread):
github.com - CSG.ConnectorList does not work in current code on github · Issue #299 · jscad/OpenJSCAD.org
Christian Brunschen
they seem to report somewhat different versions (1.0.1 on http://openjscad.org, 1.0.3 running locally). The two 'dist/index.js' files also seem quite different.Oct 17, 2017
Christian Brunschen
Hi! Just wondering, did your hunch play out?
