    remote.pl for dockerized openjscad
    3 Posts 2 Posters 3.1k Views 1 Watching
    • WolfgangFahlW Offline
      WolfgangFahl
      In remote.pl I found the following comment:
      2017/09/23: 0.005: fix vulnerability: disallow file://
      In a local installation like with the docker image https://github.com/BITPlan/docker-openjscad this is probably not such a big issue.
      Where can i find a remote.pl that is more suite to the local installation use case?
      • kaosat-devK Offline
        kaosat-dev
        Hi Wolfgang !
        Sorry but I am not aware of another version of that script.
        Do you need the re-rewrite capability provided by that file ? The only use case is for being able to open jscad designs from other sites (to dance around CORS issue).
          WolfgangFahl
          Thank you kaosat-dev for looking into this. I added the issue:
          https://github.com/jscad/OpenJSCAD.org/issues/438
          to more clearly show what the problem is. Locally I can work with the drag&drop solution or with the workspace-mounting approach of the dockerized OpenJSCAD at https://github.com/BITPlan/docker-openjscad
