    simple hull fonction
    1835
    • I
      imkael last edited by
      hello every body,
      I'm trying to do a simple thing a hull between a cube and a cylinder( something very easy to do in openscad:
      //!OpenSCAD
      hull() {
      cube(10,center =true);
      translate([0,0,60]) cylinder(1,5,5);
      but i'm trying to do this in openjscad for hours now without any result.
      Please help.
      Thanks in advance
      Best regards
      • I
        imkael @z3dev last edited by
        @z3dev thanks for your answer, i will check that. Any idea of the release date of the V2?
        Thanks again.
        Best regards
          Sorry, but the hull of 3D solids is not possible with V1 of OpenJSCAD.org.
          There's a pull request for this which uses an external library, if you would like to try modifying the CSG library locally.
          PR #134
          Otherwise, please be patient as we hope to include this in V2.
          I 1 Reply Last reply Reply Quote 0
