    V2 Update 2020 Oct 24
    1 Posts 1 Posters 426 Views 1 Watching
      Please get the latest version of JSCAD V2, as there have been some bug fixes.
      Bug Fixes:
      web: allow other file types to be loaded into the fake FS of the WEB UI
      web: improve tracking of rotate/pan/zoom changes (BIG thanks to @hrgdavor)
      svg-deserializer: corrected determination and processing of ArrayBuffer data
      Successfully published:
      • @jscad/cli@2.0.0-alpha.9
      • @jscad/core@2.0.0-alpha.9
      • @jscad/io@2.0.0-alpha.8
      • @jscad/stl-deserializer@2.0.0-alpha.7
      • @jscad/web@2.0.0-alpha.11
        lerna success published 5 packages
      BIG NOTE: The V2 website is also using this release.
      For those already using local copy of JSCAD V2, be sure to run the following commands.
      git pull
      npm run clean (and answer Y)
