    V2 Update 2020 Nov 11
    1 Posts 1 Posters 811 Views 1 Watching
      Please get the latest version of JSCAD V2, as there have been some changes as well as bug fixes.
      There are now four pre-packed libraries. NOTE: Some of the library names have been changed.
      • core: jscad-core.min.js, UMD library exporting 'jscadCore'
      • modeling: jscad-modeling.min.js, UMD library exporting 'jscadModeling'
      • web: jscad-web.min.js, UMD library exporting 'jscadWeb'
      • regl-renderer: jscad-regl-renderer.min.js, UMD library exporting 'jscadReglRenderer'
      For more information see the README file for the packages.
      New Features:
      all: standardize package contents, improving published packages
      core: added build script and configuration for publishing
      Bug Fixes:
      io: corrected all meta data in deserializer and serializers, and corrected to use package version in meta data
      io-utils: split out Blob and converted to ES5 class, added test suite
      io-utils: converted BinaryReader to ES5 class
      modeling: corrected extrudeWalls to ignore invalid polygons(walls) which occurs if slices overlap
      modeling: corrected slice creation for negative (-x) biased shapes
      regl-renderer: corrected orientation of presets
      regl-renderer: adjusted default rotation rate for auto-rotate
      regl-renderer: corrected entitiesFromSolids to use transforms from geometries
      regl-renderer: corrected zoomToFit to ignore 2D geomerties and visual entites (draw commands)
      web: corrected keyboard shortcuts and selection of auto-rotate
      web: changed the file system watcher to use setTimeout(), and calculate dynamic delays
      web: changed intial camera position so X and Y axis point to positive coordinates
      Successfully published:
      • @jscad/cli@2.0.0-alpha.10
      • @jscad/core@2.0.0-alpha.10
      • @jscad/examples@2.0.0-alpha.5
      • @jscad/amf-deserializer@2.0.0-alpha.7
      • @jscad/amf-serializer@2.0.0-alpha.8
      • @jscad/dxf-deserializer@2.0.0-alpha.7
      • @jscad/dxf-serializer@2.0.0-alpha.7
      • @jscad/io-utils@2.0.0-alpha.7
      • @jscad/io@2.0.0-alpha.9
      • @jscad/json-deserializer@2.0.0-alpha.7
      • @jscad/json-serializer@2.0.0-alpha.7
      • @jscad/obj-deserializer@2.0.0-alpha.7
      • @jscad/stl-deserializer@2.0.0-alpha.8
      • @jscad/stl-serializer@2.0.0-alpha.7
      • @jscad/svg-deserializer@2.0.0-alpha.7
      • @jscad/svg-serializer@2.0.0-alpha.8
      • @jscad/x3d-serializer@2.0.0-alpha.8
      • @jscad/modeling@2.0.0-alpha.7
      • @jscad/array-utils@2.0.0-alpha.4
      • @jscad/img-utils@2.0.0-alpha.4
      • @jscad/regl-renderer@2.0.0-alpha.9
      • @jscad/vtree@2.0.0-alpha.8
      • @jscad/web@2.0.0-alpha.12
      BIG NOTE: The V2 website is also using this release.
      There's on-line documentation as well for those needing additional information about the modeling API.
      For those using a local copy of JSCAD V2, be sure to run the following commands.
      git pull
      npm run clean (and answer Y)
      1 Reply Last reply Reply Quote 2
