    V2 Update 2020 Dec 04
    1 Posts 1 Posters 401 Views 1 Watching
      Please get the latest version of JSCAD V2, as there have been some changes as well as bug fixes.
      New Features:
      modeling: initial typescript declarations (#726)
      web: enhanced to support auto-reloading from livereload (#729)
      Thanks to @ahdinousaur for the Typescript declarations.
      Thanks to @hrgdavor for the livereload functionality
      Bug Fixes:
      svg-deserializer: enhanced to support mirror transforms
      svg-deserializer: corrected order of SVG transforms
      svg-deserializer: fixed translate transforms with one value
      svg-deserializer: added X/Y translate for group and use entities
      svg-deserializer: corrected size of rectangles when instantiating
      regl-renderer: calculate a variable distance to the camera when pannning
      Successfully published:
      • @jscad/cli@2.0.0-alpha.11
      • @jscad/core@2.0.0-alpha.11
      • @jscad/amf-deserializer@2.0.0-alpha.8
      • @jscad/amf-serializer@2.0.0-alpha.9
      • @jscad/dxf-deserializer@2.0.0-alpha.8
      • @jscad/dxf-serializer@2.0.0-alpha.8
      • @jscad/io-utils@2.0.0-alpha.8
      • @jscad/io@2.0.0-alpha.10
      • @jscad/json-deserializer@2.0.0-alpha.8
      • @jscad/json-serializer@2.0.0-alpha.8
      • @jscad/obj-deserializer@2.0.0-alpha.8
      • @jscad/stl-deserializer@2.0.0-alpha.9
      • @jscad/stl-serializer@2.0.0-alpha.8
      • @jscad/svg-deserializer@2.0.0-alpha.8
      • @jscad/svg-serializer@2.0.0-alpha.9
      • @jscad/x3d-serializer@2.0.0-alpha.9
      • @jscad/modeling@2.0.0-alpha.8
      • @jscad/regl-renderer@2.0.0-alpha.10
      • @jscad/vtree@2.0.0-alpha.9
      • @jscad/web@2.0.0-alpha.13
      BIG NOTE: The V2 website is also using this release.
      There's on-line documentation as well for those needing additional information about the modeling API.
      For those using a local copy of JSCAD V2, be sure to run the following commands.
      git pull
      npm run clean (and answer Y)
