    Why am I getting "Uncaught TypeError: CSG.Path2d is not a constructor"?
    General Discussions
    5
    1381
    • wildjerry
      wildjerry last edited by wildjerry
      I'm new to both Open(J)Scad and javascript in general, and I keep getting this error.
      Line: 97,col: 9
      (blob:https://openjscad.org/f3af8c9b-afdd-46ee-ad07-40d1f04dd681)
      My code is intended to create an array of 2d shapes, then render them in either 2d or 3d(using a revolve extrude) with a union().
      function main(params) {
          sketches = [
              square([10,2]),
              square([3,20]),
              new CSG.Path2d([
                  [0,0],
                  [0,9],
                  [19,0],
                  ],true),
          return render(sketches,params.dimension);
      function getParameterDefinitions() {
              { name: 'dimension', type: 'checkbox', checked: false, caption: 'render in 3d?' },
      function render(obj,dim) {
              if (dim){
              extrudes =[];
              for (var i of obj){
                  extrudes.push(rotate_extrude(i));
              return union(extrudes);
          } else {
              return union(sketches);
        gilboonet @wildjerry last edited by
        V1 color syntax is color("Red", extrudes[0])
        • wildjerry
          Related Noob Question: I'm trying to add color to my script, and I'm getting this error:
          Uncaught TypeError: object.setColor is not a function
          Line: 6919,col: 17
          My current code is:
              sketches = [
                  square([10,2]),
                  square([3,10]),
                  new polygon([
                      [0,0],
                      [9,0],
                      [3,9],
                      ],true),
          function render(obj,dim,colors) {
              if (dim){
                  extrudes =[];
                  for (var i of obj){
                  extrudes[0]=color(extrudes[0],"Red")
                  extrudes[1]=color(extrudes[1],"Red")
                  extrudes[2]=color(extrudes[2],"White")
              else {
          The only difference between the fixed version of the code and this one is the added colors after I extrude. Based on the documentation, I don't see why this doesn't work.
          gilboonet 1 Reply Last reply Reply Quote 0
          • wildjerry
            Thank You!
              z3dev @wildjerry last edited by
              @wildjerry Cool name! Welcome.
              OK. You just need to change Path2d to Path2D.
              However... V1 JSCAD cannot render paths. So, you should use something like this for 2D shapes.
              let p1 = polygon([ [0,0],[3,0],[3,3] ])
              Now, that should get you moving.
