    V2 Update 2021 Feb 07
    1
    1
    324
      z3dev last edited by z3dev
      Please get the latest version of JSCAD V2, as there have been some changes as well as bug fixes.
      Features:
      modeling: adding new class of operations to modeling; modifiers
      modeling: enhanced options to extrudeFromSlices
      Bug Fixes:
      core: changed serializeSolids to apply transforms before serializing, correcting issues with mirroring
      web: corrected remote fetching of binary formats ([#764])
      web: corrected theme names ([#764])
      Successfully published:
      • @jscad/cli@2.0.0-alpha.13
      • @jscad/core@2.0.0-alpha.13
      • @jscad/examples@2.0.0-alpha.6
      • @jscad/amf-deserializer@2.0.0-alpha.10
      • @jscad/amf-serializer@2.0.0-alpha.11
      • @jscad/dxf-deserializer@2.0.0-alpha.10
      • @jscad/dxf-serializer@2.0.0-alpha.10
      • @jscad/io-utils@2.0.0-alpha.10
      • @jscad/io@2.0.0-alpha.12
      • @jscad/json-deserializer@2.0.0-alpha.10
      • @jscad/json-serializer@2.0.0-alpha.10
      • @jscad/obj-deserializer@2.0.0-alpha.10
      • @jscad/stl-deserializer@2.0.0-alpha.11
      • @jscad/stl-serializer@2.0.0-alpha.10
      • @jscad/svg-deserializer@2.0.0-alpha.10
      • @jscad/svg-serializer@2.0.0-alpha.11
      • @jscad/x3d-serializer@2.0.0-alpha.11
      • @jscad/modeling@2.0.0-alpha.10
      • @jscad/regl-renderer@2.0.0-alpha.12
      • @jscad/vtree@2.0.0-alpha.11
      • @jscad/web@2.0.0-alpha.15
      BIG NOTE: The V2 website is also using this release.
      There's on-line documentation as well for those needing additional information about the modeling API.
      For those using a local copy of JSCAD V2, be sure to run the following commands.
      git pull
      npm run clean (and answer Y)
