V2 Update 2021 Mar 07
Please get the latest version of JSCAD V2, as there have been some changes as well as bug fixes.
Features:
modeling: rename relativeTo option to align and center
modeling: revisit modifiers, adding insert of points for T-junctions during triangulation
amf-serializer: enhanced to snap and triangulate 3D geometries before serialization
dxf-serializer: enhanced to snap and triangulate 3D geometries before serialization
stl-serializer: enhanced to snap and triangulate 3D geometries before serialization
x3d-serializer: enhanced to snap and triangulate 3D geometries before serializationBug Fixes:
web: corrected check of scope for key events
modeling: added validation of points and faces in polyhedronSuccessfully published:
- @jscad/cli@2.0.0-alpha.14
- @jscad/core@2.0.0-alpha.14
- @jscad/examples@2.0.0-alpha.7
- @jscad/amf-deserializer@2.0.0-alpha.11
- @jscad/amf-serializer@2.0.0-alpha.12
- @jscad/dxf-deserializer@2.0.0-alpha.11
- @jscad/dxf-serializer@2.0.0-alpha.11
- @jscad/io-utils@2.0.0-alpha.11
- @jscad/io@2.0.0-alpha.13
- @jscad/json-deserializer@2.0.0-alpha.11
- @jscad/json-serializer@2.0.0-alpha.11
- @jscad/obj-deserializer@2.0.0-alpha.11
- @jscad/stl-deserializer@2.0.0-alpha.12
- @jscad/stl-serializer@2.0.0-alpha.11
- @jscad/svg-deserializer@2.0.0-alpha.11
- @jscad/svg-serializer@2.0.0-alpha.12
- @jscad/x3d-serializer@2.0.0-alpha.12
- @jscad/modeling@2.0.0-alpha.11
- @jscad/array-utils@2.0.0-alpha.5
- @jscad/regl-renderer@2.0.0-alpha.13
- @jscad/vtree@2.0.0-alpha.12
- @jscad/web@2.0.0-alpha.16
BIG NOTE: The V2 website is also using this release.
There's on-line documentation as well for those needing additional information about the modeling API.
For those using a local copy of JSCAD V2, be sure to run the following commands.
NOTE: Development dependencies have been bumped due to changes in Node.js 14.
git pull npm run clean (and answer Y) rm -rf node_modules npm run bootstrapBoth CLI and WEB UI are usable for creating designs. In the WEB UI, it's best to drag-n-drop project folders to the window, and work with the pieces via a favorite editor. If "Enable auto reload" is checked then changes will be detected, and rendered again.
