    Can not get View type: Orthographic to work.
    5 Posts 3 Posters 1.7k Views 1 Watching
    • David BoltD Offline
      David Bolt
      I can not seem to get the View type: Orthographic to work.
      here is my design
      https://www.openjscad.xyz/?uri=https://sfcknox.org/synergyData/CAD/BusShelter.js
      if I type "t" to see the top view, that works,
      then type "o" to see the Orthographic view, but the perspective view is still visible.
      Are there more steps to use the Orthographic view?
        @david-bolt nice to see another design. 👍
        I will double check but I don't think that Orthographic view has been enabled.
        David BoltD 1 Reply Last reply Reply Quote 0
          David Bolt @z3dev
          @z3dev
          What does it take to to enable the Orthographic view?
          z3devZ Ion 0I 2 Replies Last reply Reply Quote 0
            z3dev @David Bolt
            @david-bolt good question!
            It may require changes to the regl-render. You can probably start there, and see if there's support. I would guess that the initial view can be changed for the demo.html
            • Ion 0I Offline
              Ion 0 @David Bolt
              @david-bolt one suggestion from what i've tried could be to set the camera position for regular perspective camera further away as an orthographic camera is just a perspective camera at infinity
