    V2 Update : 2020 SEP 02
    2 Posts 2 Posters 450 Views 2 Watching
      Please get the latest version of JSCAD V2, as there have been some bug fixes.
      web: fixes for slider, group, and choice parameter types
      regl-renderer: various fixes to renderer
      In addition, all the dependencies (libraries used by JSCAD) have been bumped to the latest versions. For those already using JSCAD V2, be sure to run the following commands.
      git pull
      npm run clean (and answer Y)
      The WEB UI is now quite usable for creating designs. It's best to drag-n-drop project folders to the window, and work with the pieces via a favorite editor. If "Enable auto reload" is checked then changes will be detected, and rendered again.
        I applied the update, and it's ok. Thank you for the commands to run, I only knew about git pull, not the two other commands.
