    V2 Update : 2020 SEP 08
    1 Posts 1 Posters 382 Views 1 Watching
    • z3devZ Online
      Please get the latest version of JSCAD V2, as there have been some major bug fixes.
      WEB UI now works on Windows 10, across all browsers (except Explorer which is not ES6 compliant)
      The examples have been converted to V2 JSCAD, and more. (Thanks to @SimonClark for making the changes, and adding many more new examples!)
      Summary:
      core: corrected webRequire to use posix paths
      examples: examples overhaul for V2 JSCAD
      modeling: Adding & improving tests, docs, removing some equals()
      modeling: fix torus offset when outerRotation is supplied
      For those already using JSCAD V2, be sure to run the following commands.
      git pull
      npm run clean (and answer Y)
