    V2 Update : 2020 SEP 18
    2 Posts 1 Posters 516 Views 1 Watching
      Please get the latest version of JSCAD V2, as there have been some major bug fixes, and new functional enhancements.
      WEB UI now has touch gestures for mobile devices, across all browsers (except Explorer which is not ES6 compliant.)
      There's a new align function which can align a set of objects using various X, Y, and Z orientations, as well as centers. Thanks to @SimonClark for the contribution!
      New Features:
      modeling: add transforms.align() and measurements.measureAggregateBoundingBox() functions
      dxf-serializer: (export) added support for colors
      svg-deserializer: (import) added support for segments option
      Bug Fixes:
      web: fix json import
      web: support sparse arrays from main() (fixes from @MathieuLoutre)
      web: V2 enable multi-gesture touch events for mobile devices
      For those already using JSCAD V2, be sure to run the following commands.
      git pull
      npm run clean (and answer Y)
      z3devZ 1 Reply Last reply Reply Quote 1
        z3dev @z3dev
        I forgot to mention that the renderer now includes a packaged library. See 'packages/utils/regl-renderer/dist/reglRenderer.js'
        This library can be used standalone in websites to render JSCAD geometries. This is for developers that want to implement other javascript components, like React.js based components, etc.
