    Passing multiple solids to entitiesFromSolids
    943
    • BarbourSmith
      BarbourSmith last edited by
      Hello everyone,
      I have been playing around with the built in render and using the entitiesFromSolids function. Thank you devs for kindly including that package!
      I believe the source for the function can be found here: https://github.com/jscad/OpenJSCAD.org/blob/V2/packages/utils/regl-renderer/src/geometry-utils/entitiesFromSolids.js
      I'm having trouble with understanding how to pass multiple solids. I can union them together and get that to display no problem, but my reading of the function is that it should support passing multiple solids at the same time which would be faster for me.
      Can anyone confirm that multiple solids can be passed and if so point me to how to do it?
      • BarbourSmith
        Thank you so much!
        Honestly looking at it now I don't see how I didn't understand how it worked. Union takes an array of solids so that would make the most sense. Thanks!
          z3dev last edited by
          Be careful.. there are V1 and V2 versions of the conversion routines. And only V2 is being tested.
          geometry-utils
          geometry-utils-V2
          I see the confusion. The entitiesFromSolids function is not well documented. 😞
          The function signiture is:
          const entitiesFromSolids = (params, solids)
          And solids must be a single V2 geometry or an array of V2 geometry.
