    V2 Update 2020 OCT 11
    2 Posts 2 Posters 680 Views 1 Watching
      Please get the latest version of JSCAD V2, as there have been some bug fixes.
      Bug Fixes:
      modeling: added startAngle and endAngle options to ellipse / circle
      modeling: corrected offset if segments are paralell
      modeling: allow geom2.fromPoints() to accept the same closing point as the first point
      modeling: removed connectors from public api (See issue #679)
      web: enhanced remote.pl to support all V2 external formats (remote proxy)
      In addition, the 'hoisting' of 'ava' and 'nyc' has been corrected. The bootstrap process is now exceedingly fast.
      Also, test and coverage scripts can be executed inside the individual packages.
      BIG NOTE: The V2 website is also using this release.
      For those already using JSCAD V2, be sure to run the following commands.
      git pull
      npm run clean (and answer Y)
      Successfully published:
      • @jscad/cli@2.0.0-alpha.8
      • @jscad/core@2.0.0-alpha.8
      • @jscad/examples@2.0.0-alpha.4
      • @jscad/amf-deserializer@2.0.0-alpha.6
      • @jscad/amf-serializer@2.0.0-alpha.7
      • @jscad/dxf-deserializer@2.0.0-alpha.6
      • @jscad/dxf-serializer@2.0.0-alpha.6
      • @jscad/io-utils@2.0.0-alpha.6
      • @jscad/io@2.0.0-alpha.7
      • @jscad/json-deserializer@2.0.0-alpha.6
      • @jscad/json-serializer@2.0.0-alpha.6
      • @jscad/obj-deserializer@2.0.0-alpha.6
      • @jscad/stl-deserializer@2.0.0-alpha.6
      • @jscad/stl-serializer@2.0.0-alpha.6
      • @jscad/svg-deserializer@2.0.0-alpha.6
      • @jscad/svg-serializer@2.0.0-alpha.7
      • @jscad/x3d-serializer@2.0.0-alpha.7
      • @jscad/modeling@2.0.0-alpha.6
      • @jscad/array-utils@2.0.0-alpha.3
      • @jscad/regl-renderer@2.0.0-alpha.8
      • @jscad/vtree@2.0.0-alpha.7
      • @jscad/web@2.0.0-alpha.10
      • BarbourSmithB Offline
        BarbourSmith
        Very exciting! I can't wait to give the latest a try.
