    2D slice from extruded polygon after substraction
    4
    9
    1619
    • Ion
      Ion last edited by
      Hello
      First of all, would like to thank the developers who made this framework possible.
      I am starting off with a linearly extruded polygon and then subtract a cube out of it.
      Then I want to get a 2d slice in vertical plane. To achieve this I am going through all polygons and all vertices from a very thin slice ignoring all polygons with same z-axis (walls) and extract the x,y and ignore the z altogether.
      this.profile3D.polygons.forEach(function (polygon, index) {
            let local_this2 = local_this
            polygon.vertices.forEach(function (v, i) {
              let av_arr = polygon.vertices.map(function (x) {
                return parseInt(x[1] as any)
              }) as Array<number>
              let is_vertical = new Set(av_arr).size < 2
              if (!is_vertical) {
                local_this2.profile2D.push([v[0], v[2]])
      Finally I sort of get the 2d slice but with some points "tangled" (shape front end)
      How can I make sense of the mesh's structure to be able to walk the mesh so points are in order and correctly joined?
      I've excluded the "walls". The mesh seems to be a 4 pct polygon and sometimes a 3 point polygon. More complex shapes turn out more tangled points.
      Is there a common layout of the mesh that I can lookup somewhere else? I have tried checkout out the code but could not figure it out.
      I have also tried extracting the x,y of any 2 corners of the 4 pct polygon which are not "vertical walls/sides"
              }) as Array<number>
              if (!is_vertical) {
                local_this2.profile2D.push([polygon.vertices[2][0], polygon.vertices[0][2]])
      Artefacts like this started to come out but no luck with any combination.
      Any suggestions are appreciated. Thanks!
      P.S Wish my skills would be good enough to contribute.
        gilboonet @Ion 0 last edited by
        @Ion-0 That's great !
        • Ion 0
          Ion 0 @gilboonet last edited by
          @gilboonet Thanks for the response. I believe you mean the "sides" are rendered using polygons. indeed they are lots of polygons. I might give that a try using the 2d constructive geometry. i've gotten the result right using the fromfakepolygons routine.
          • Ion 0
            Ion 0 @z3dev last edited by Ion 0
            @z3dev
            I have got it working using the routine pointed at by you. it was a bit confusing as it throws error for polygons with more than "2 dimension" and the axis was different.
            gilboonet 1 Reply Last reply Reply Quote 0
              @Ion-0 If I approximate your design, and get a slice of it, I have a set of 3 polygons
              Ion 0 1 Reply Last reply Reply Quote 0
              • Ion 0
                @z3dev thanks!
                • Ion 0
                  @gilboonet The whole 2d contour is one single polygon of points. where should i get multiple polygons from? from the sides?
                    Hello, did you try to unify the polygons ? I have some code that does the same kind of thin slicing and the 2d slice is an union of the polygons.
                      z3dev @Ion last edited by z3dev
                      @Ion Welcome!
                      You are already doing things that 'normal' designers don't attempt. 🙂
                      There's a piece of code that does a very simular thing, converting 3D polgons (from boolean operations) to 2D sides. This might help you to understand a little more about the 2D geometry (geom2).
                      https://github.com/jscad/OpenJSCAD.org/blob/V2/packages/modeling/src/operations/booleans/fromFakePolygons.js
                      Ion 0 2 Replies Last reply Reply Quote 0
