    using vector operations (subtract)
    4
    851
      gilboonet last edited by
      Hello,
      yesterday I needed to modify my 2 axis slicer script for it to be compatible with latest v2 version. The error shown into web console was about subtract, so I first thought there was a problem with CSG subtract and discarded the code using it, but indeed it was vec3.subtract that I'm using as a replacement of now deprecated minus(). I replaced it with
      //d = vec3.subtract(b[1], b[0]);
      d = [b[1][0]-b[0][0], b[1][1]-b[0][1], b[1][2]-b[0][2]];
      but isn't there anymore a way to use vector operations like subtract() because it helps keeping the code easy to read.
      z3dev 2 Replies Last reply Reply Quote 0
        gilboonet @z3dev last edited by
        @z3dev Thanks, I will change to subtract(a, a, b)
          z3dev @gilboonet last edited by
          You can find the API documentation at www.Openjscad.xyz/docs/
          There should be some simple examples as well.
            @gilboonet you hit one of the differences in the maths.
            Change
            subtract(a, b) to subtract(a, a, b)
            If you need to then create a new vec.
            subtract(vec3.create(), a, b)
            gilboonet 1 Reply Last reply Reply Quote 0
