    Use jscad in vue
    8 Posts 2 Posters 1.9k Views 1 Watching
    • jess yanJ Offline
      jess yan
      @z3dev I want to develop a web system that displays CAD models based on jscad and can adjust the models through simple parameter configuration. The scene code is converted to vue, the scene can be displayed normally, but how to add the model to the scene smoothly? I can't find related content in jscad-web.
      • z3devZ Online
        @jess-yan Welcome!
        The WEB UI is based on a different reactive framework called 'most'. I would not recommend using this.
        You might be interested in the small VUE components that I created to show how to use JSCAD within the VUE framework.
        https://github.com/z3dev/vue-components
        It's still in progress so let me know if you have any issues.
        jess yanJ 1 Reply Last reply Reply Quote 0
        • jess yanJ Offline
          jess yan
          @z3dev Thank you for your help, good news! I successfully built a model display system using vue+JSCAD. It can directly display .dxf files. But I was frustrated to find that my system cannot display 2D graphics.截屏2021-09-10 下午6.33.27.png
          When did I have a problem because the system has no abnormal information. 2D files can also be successfully compiled, that is, there is no display on the canvas.
          My key is to be consistent with the key code in vue-components. I didn't use vue-components directly, and I can also key code on the basis of vue.
          export default {
            props: {
              solids: {
                type: Array,
              grid: {
                type: Object,
              axis: {
                type: Object,
              cameraPosition: {
                type: Array,
                default: () => [150, -180, 233],
            data() {
              return {
                render: () => {},
                updateView: true,
                rotateDelta: [0, 0],
                panDelta: [0, 0],
                zoomDelta: 0,
                zoom2Fit: false,
                // state to track mouse
                mouse: {
                  buttons: 0,
                  shiftKey: false,
                  isOrbiting: false,
                  lastClick: 0, // ms
                  lastZoom: 0,
                controls: orbitControls.defaults,
                camera: {
                  ...perspectiveCamera.defaults,
                  position: this.cameraPosition,
            computed: {
              gridOptions() {
                const {
                  show = false,
                  color = [0, 0, 0, 1],
                  subColor = [0, 0, 1, 0.5],
                  fadeOut = false,
                  transparent = false,
                  size = [200, 200],
                  ticks = [50, 5],
                } = this.grid
                return {
                  visuals: {
                    drawCmd: 'drawGrid',
                    show,
                    color,
                    subColor,
                    fadeOut,
                    transparent,
                  size,
                  ticks,
              axisOptions() {
                const { show = true } = this.axis
                return {
                  visuals: {
                    drawCmd: 'drawAxis',
                    show,
              content() {
                return {
                  // define the visual content
                  camera: this.camera,
                  drawCommands: {
                    drawGrid: drawCommands.drawGrid,
                    drawAxis: drawCommands.drawAxis,
                    drawMesh: drawCommands.drawMesh,
                  entities: [this.gridOptions, this.axisOptions, ...this.solids],
            watch: {
              solids() {
                this.updateView = true
              grid() {
              cameraPosition(position) {
                this.camera.position = position
            created() {
              numberOfInstances++
              this.id = numberOfInstances
            mounted() {
              this.initializeRenderer()
            methods: {
              initializeRenderer() {
                this.$el.id = `viewer${this.id}`
                const width = this.$el.clientWidth
                const height = this.$el.clientHeight
                perspectiveCamera.setProjection(this.camera, this.camera, {
                  width,
                  height,
                perspectiveCamera.update(this.camera, this.camera)
                // prepare the renderer
                const setupOptions = {
                  glOptions: { container: this.$el },
                this.renderer = prepareRender(setupOptions)
                window.addEventListener('resize', () => {
                // 告诉浏览器希望执行一次动画,并在下次重绘制前执行回调函数
                window.requestAnimationFrame(this.updateAndRender)
              updateAndRender() {
                // 处理相机和轨道
                this.doRotatePanZoom()
                if (this.updateView) {
                  const updates = orbitControls.update({
                    controls: this.controls,
                  this.controls = { ...this.controls, ...updates.controls }
                  this.updateView = this.controls.changed
                  this.camera.position = updates.camera.position
                  perspectiveCamera.update(this.camera)
                  this.resize()
                  const { content } = this
                  // TODO 这里的处理不知道是否合适
                  content.entities = content.entities
                    .reduce((pre, cur) => {
                      if (!cur.visuals) {
                        pre.push(...entitiesFromSolids({}, cur))
                      pre.push(cur)
                      return pre
                    .filter((item) => item.visuals)
                  this.renderer(content)
              doRotatePanZoom() {
                let {
                  rotateDelta,
                  panDelta,
                  zoomDelta,
                  zoom2Fit,
                  controls,
                  camera,
                  content,
                } = this
                // 旋转增量存在
                if (rotateDelta[0] || rotateDelta[1]) {
                  const updated = orbitControls.rotate(
                    { controls, camera, speed: rotateSpeed },
                    rotateDelta
                  this.controls = { ...controls, ...updated.controls }
                  this.rotateDelta = [0, 0]
                // 平移增量存在
                if (panDelta[0] || panDelta[1]) {
                  const updated = orbitControls.pan(
                    { controls, camera, speed: panSpeed },
                    panDelta
                  this.camera.position = updated.camera.position
                  this.camera.target = updated.camera.target
                  this.panDelta = [0, 0]
                // 缩放增量存在
                if (zoomDelta) {
                  const updated = orbitControls.zoom(
                    { controls, camera, speed: zoomSpeed },
                    zoomDelta
                  this.zoomDelta = 0
                // 缩放到合适比例
                if (zoom2Fit) {
                  // 缩放到缩放比为2
                  controls.zoomToFit.tightness = 2
                  const updated = orbitControls.zoomToFit({
                    controls,
                    camera,
                    entities: content.entities.filter((entity) => entity.geometry),
                  this.zoom2Fit = false
              resize() {
                // 像素比例
                const pixelRatio = window.devicePixelRatio || 1
                // 获取元素大小和相对于视口位置
                const bounds = this.$el.getBoundingClientRect()
                // 计算元素边界尺寸
                const width = (bounds.right - bounds.left) * pixelRatio
                const height = (bounds.bottom - bounds.top) * pixelRatio
                // 获取元素真实尺寸
                const prevWidth = this.$el.width
                const prevHeight = this.$el.height
                // 如果尺寸发生变化
                if (prevWidth !== width || prevHeight !== height) {
                  // 更新元素的尺寸
                  this.$el.width = width
                  this.$el.height = height
                  // 设置相机投影
                    width,
                    height,
                  // 更新相机
              // mouse event handling
              onMouseDown(event) {
                const { mouse } = this
                mouse.buttons = event.buttons
                mouse.shiftKey = event.shiftKey
                mouse.isOrbiting = true
              onMouseUp() {
                const now = Date.now()
                if (mouse.lastClick) {
                  const ms = now - mouse.lastClick
                  if (ms < doubleClickSpeed) {
                    if (mouse.isOrbiting) {
                      this.zoom2Fit = true
                mouse.lastClick = now
                mouse.buttons = 0
                mouse.shiftKey = false
                mouse.isOrbiting = false
              onMouseMove(event) {
                const { mouse, panDelta, rotateDelta } = this
                  if (mouse.shiftKey) {
                    panDelta[0] -= event.movementX
                    panDelta[1] += event.movementY
                  } else {
                    rotateDelta[0] += event.movementX
                    rotateDelta[1] -= event.movementY
              onScroll(event) {
                event.preventDefault()
                this.zoomDelta = event.deltaY
          z3devZ 2 Replies Last reply Reply Quote 0
          • jess yanJ Offline
            jess yan @z3dev
            @z3dev said in Use jscad in vue:
            @jess-yan Welcome!
            For vue-components, I removed vuex related content, which I think is cleaner and easier to use.
            • z3devZ Online
              z3dev @jess yan
              @jess-yan you found a bug! 🐜 i'll patch today, and let you know when the new version is available.
              • z3devZ Online
                z3dev @jess yan
                @jess-yan Here's the fix...
                diff --git a/src/viewerComponent.js b/src/viewerComponent.js
                index 95b9321..f5bbbdd 100644
                --- a/src/viewerComponent.js
                +++ b/src/viewerComponent.js
                @@ -77,6 +77,7 @@ const setupRenderer = (containerElement, data) => {
                     drawCommands: {
                +      drawLines: drawCommands.drawLines,
                • jess yanJ Offline
                  jess yan @z3dev
                  @z3dev OK! Can now display 2D!!!
                  • z3devZ Online
                    z3dev @jess yan
                    @jess-yan Super! Please let us know when a working website is available. There are many of us that want to extend JSCAD in various ways.
