    How to select the rendered model with the mouse?
    5 Posts 3 Posters 1.5k Views 2 Watching
    • jess yanJ Offline
      jess yan
      Interesting question, how to select the rendered model with the mouse, and then edit the parameters of the selected model?
      I did not find the relevant content in the user manual!
      @z3dev Have you implemented related functions?
        z3dev @jess yan
        i haven't seen this functionality in any of the various websites. it's probably possible but way outside of the goals of JSCAD.
        @hrgdavor mentioned that Three.js has this functionality but again implementation is not going to be easy.
        jess yanJ 1 Reply Last reply Reply Quote 0
        • jess yanJ Offline
          jess yan @z3dev
          @z3dev OK! If you render multiple models at the same time, you can only select the model from the list and edit the model parameters. This is the solution I thought of, although it is not perfect.
            z3dev @jess yan
            @jess-yan that's not so different than some of the mainstream cad applications. for example, blender allows the selection of the model using a mouse click, but just selects the model from the tree of models on the right. any changes to the model are made to the tree.
            hrgdavorH 1 Reply Last reply Reply Quote 0
              hrgdavor @z3dev
              @z3dev @jess-yan yup. it is not implemented right now. But such feature has a lot more to consider to be implemented.
              It may be beneficial to start a discussion on git to see what would be expectation of such functionality and what it would take to implement it.
