    Unfolder V2, test on Ubuntu with Chromium
    3 Posts 2 Posters 725 Views 2 Watching
      Hello, I'm testing the Unfolder. I'm starting with Chromium on Ubuntu. It works and the 2d output exports as svg, but it doesn't perform the last step that packs small pieces to reduce page count, and there's no error. To pack those pieces, I use align() and measureAggregateBoundingBox().
      function aggregatePieces (P) {// join small pieces
      	function minX (a, b) { return a.x > b.x }
      	function minY (a, b) { return a.y > b.y }
      	const align_centerXY = ['center','center','none']
      	var r = []
      	for (var i = 0, l = P.length; i < l; i++) { // measure pieces
      		var b = measureAggregateBoundingBox(P[i])
      		r.push({d:align({modes:align_centerXY, grouped:true}, P[i]),
      						x: b[1][0] - b[0][0], y: b[1][1] - b[0][1]})
      	if (r.length > 1) {
      		var ok = true
      		do { // try to group smallest X pieces
      			r.sort(minX)
      			if (r[1] !== undefined) {
      				if ((r[0].x + r[1].x) < V.frame[0]) {
      					r[0].d.push(translateX((r[0].x + r[1].x) / 2, r[1].d))
      					r[0].d = align({modes:align_centerXY, grouped:true}, r[0].d)
      					var b = measureGroup(r[0].d)
      					r[0].x = b[0]
      					r[0].y = b[1]
      					r[1].d = null
      					r.splice(1, 1)
      				} else {
      					ok = false
      			} else
      				ok = false
      		} while (ok)
      		var ok = true
      		do { // try to group smallest Y pieces
      			r.sort(minY)
      				if ((r[0].y + r[1].y) < V.frame[1]) {
      					r[0].d.push(translateY((r[0].y + r[1].y) / 2, r[1].d))
      					r[0].x = b[0]
      					r[0].y = b[1]
      					r[1].d = null
      					r.splice(1, 1)
      				} else {
      					ok = false
      			} else
      				ok = false
      		} while (ok)
      	return r
        gilboonet @gilboonet
        @gilboonet I tried Chrome and it does the same. After some investigations I found what was wrong, it was my sort functions : return a.x > b.x that needed to be changed to return a.x - b.x.
        hrgdavorH 1 Reply Last reply Reply Quote 0
          hrgdavor @gilboonet
          @gilboonet yes, specification for sort functions is to
          • return zero if a==b
          • return neg or positive number depending if u want to sort ASC or DESC
