    Getting values from a geometry
    Scheduled Pinned Locked Moved Design Discussions
    3 Posts 2 Posters 1.6k Views 1 Watching
      Hello, I need to get sides from a geometry made of rectangles to process it line by line and apparently the sides of the rectangles are not the values, there are transforms that need to be also computed. How can I do to get the values after the transforms ? (What I want to do is sort the sides then return an unique array with for each side with as additional data its occurrence, to know if a line is a cut (1 occurrence) or a fold (2).
        z3dev @gilboonet
        @gilboonet geom2.toSides() should be called to obtain the sides. however, the sides are not ordered like a path. if you need ordering then a better option is calling toOutlines() which will provide each outline as a set of ordered points.
          gilboonet @z3dev
          @z3dev I finally resolved it by not using transforms and directly compute the center of the rectangles, that way the geometry sides were ok without any need to transform. I hope to be able to reuse that code for same kind of simple designs.
