    little V2 feedback
    12 Posts 2 Posters 3.7k Views 1 Watching
      Hello, here's a little feedback on V2. I gave it a try yesterday and the installation went perfectly on a PC with a fresh Ubuntu 20. I'm slowly discovering how things work now and I am trying to maintain my code as "simple" as possible as I'm trying to make non-programmers use jscad, but it is slightly more technical than V1 was. You can be very proud of this new jscad.
        What is difficult is to know what requires are needed, so I try to make them as large as possible.
        In the future, I will certainly try to put utility functions like degToRad into a library.
        I didn't find vec3.minus(), vec3.times, so I used respectively add and scale to replace them.
        Functions like translate or size attribute of a primitive that need an array doesn't accept a variable containing an array but only a litteral array. Are there coding basics to know to work with vec3/vec2 ?
        I wasn't able to use color library, and the generated doc about modeling/color is empty, so maybe it is not available for the moment, or did I miss something during installation ?
        z3devZ 3 Replies Last reply Reply Quote 0
          z3dev @gilboonet
          @gilboonet thanks for the nice feedback. 🙂
          FYI, you can generate documentation as well, if you need some documention on the new functional API. 😉
          npm run docs
          And open 'index.html' found in the 'out' directory.
            z3dev @gilboonet
            @gilboonet said in little V2 feedback:
            Ooops! There's a little name issue in the documention. Will be fixed soon.
              z3dev @gilboonet
              You should be able to do this...
              let mysize = [2, 3, 4]
              let myshape = primitives.cuboid({size: mysize})
                gilboonet @z3dev
                @z3dev To color I use colors.colorize([r,v,b,a], geom), read from the documentation. I generated it at the end of the installation process as it was the last step.
                  0_1591953285796_Capture d’écran de 2020-06-12 11-06-44.png It's not something important, but on the top there are captions written in white that can only be seen when there's something on the background.
                    gilboonet @z3dev
                    @z3dev I tried to use a variable with translate and got
                    ERROR:
                    Error: offset must be an array
                    my code is (last line)
                    var vol = transforms.center({}, transforms.scale(ech.fill(params.echelle), volume().csg))
                      var B = measureBounds(vol)
                      let d = vec3.add(B[1], vec3.negate(B[0]))
                      let d2 = vec3.scale(1/2, d)
                      //vol = transforms.translate([d2[0],d2[1],d2[2] ], vol)
                      vol = transforms.translate(d2, vol)
                    It works with the commented line
                      z3dev @gilboonet
                      @gilboonet nice example.
                      I understand now. Those vec3 functions return a Float32Array, which is NOT an Array. 😞
                      For now, you can use ES6 javascript syntax to make things easier.
                      vol = transforms.translate([ ...d2 ], vol)
                      By the way, the latest V2 branch has a fix for the documentation on colors.
                        z3dev @gilboonet
                        @gilboonet are you using the 'dark' theme?
                        yeah. there's still some issues in the web UI.
                          gilboonet @z3dev
                          @z3dev Yes, I'm using the dark theme (even if it's not working now). I'm on a 4K screen and V2 runs nicely. I drag & drop my project folder to run it, it always work (on 2K resolution, lots of time it shows the folder contend instead of running it). But after some drags & drops, the parameters window disappear.
                          (capture of 4K screen)
                          I'll try to run npm run docs to update the docs.
                          I'm trying to code my 2 axis interlock slicer on v2, but there are some troubles with my 3d->2d projection code with complex models, so I'm digging the code looking for anything that could help on projection, outline.
                            gilboonet @z3dev
                            @z3dev I update the docs with "npm run docs" and now documentation about color is available.
