    Debugging script
    5 Posts 4 Posters 1.3k Views 3 Watching
    • K Offline
      Ken
      I’ve become frustrated. I think JSCad may be to advanced an application for the average computer user. Here is a snippet:
      const { polygon} = require('@jscad/modeling').primitives
      const { extrudeRectangular, extrudeLinear, extrudeRotate } = require('@jscad/modeling').extrusions
      const { offset,expand } = require('@jscad/modeling').expansions
      let x =[[0,0],[-30,0],[-30,100],[40,100],[40,70],[0,70],[0,0]];
      const v1 = polygon({ points: x})
      const b1 = extrudeRectangular({height: .1 , size: 3}, v1)
      const v2 = expand({ delta: -3, corners: 'edge', segments: 8 }, v1) // api indicates v2 should be another polygon
      const b2 = extrudeRectangular({height: .1 , size: 3}, v2)
      const main = () => {
      //return v1 //ok
      //return b1 //ok
      //return v2 // looks ok, but I don't know how to examine the points
      return b2 //breaks
      module.exports = { main }
      I installed JScad-now on Windows 10 and got about 4 warnings I do not understand. I can’t get it to work.
      I use notepad++ and chrome, is there a better environment? How should an average user approach debugging? I didn’t see a console.log(polygon.toPoints()).
      What I originally wanted to do is extrudeLinear a closed path with arcs and generate shapes to .round the base and top. The exstudefromslices examples are little to advanced.
      Thanks,
      Ken Swindell
      //return v1 //ok
      //return b1 //ok
      return b2 //breaks
      Thanks,
      Ken Swindell
        Hello, you can get V2 points using :
        console.log(v2.sides)
        I'm running JSCAD using Firefox at https://openjscad.xyz/
          hrgdavor
          If you are starting in jscad and are interested in doing stuff with jscad in future join the discord channel too 🙂 https://discord.gg/UXtQcA6
          I am not sure what shape you are trying to get, but here is my guess based on a circle
          the problem with offset function is that it may produce shapes that will make problems for you down the line
          below is my attempt from some utility I have from some time ago. ... it works fr cylinder but if I use your poly v1 or v2
          some parts are ok, some are fked up
          const { expansions, primitives, maths, extrusions } = require('@jscad/modeling')
          const { polygon , circle} = primitives
          const { extrudeRectangular, extrudeLinear, extrudeRotate, extrudeFromSlices, slice } = extrusions
          const { offset,expand } = expansions
          const { mat4, line2, line3, vec2, vec3, vec4 } = maths
          let x =[[0,0],[-30,0],[-30,100],[40,100],[40,70],[0,70],[0,0]].reverse();
          return extrudeChamfer({baseSlice:circle({radius:5}), h: 10, cut:1, corners:'round'})
          //return v1 //ok
          //return b1 //ok
          return b2 //breaks
          const extrudeChamfer = ({baseSlice, h=10, cut=0, cutTop=0, cutBottom=0, tz=0, tx=0, ty=0}) => {
            cutTop = cutTop || cut;
            cutBottom = cutBottom || cut;
            let levels = [];
            if(cutBottom){
            	levels.push([0,-cutBottom]);
            	levels.push([cutBottom,0]);
            }else{
            	levels.push([0,0]);
            levels.push([h-cutTop-cutBottom,0]);
            if(cutTop){
          	  levels.push([cutTop, -cutTop]);
            return extrudeLevels({levels, baseSlice, tz, tx, ty})
          const extrudeLevels = ({levels, baseSlice, corners='edge', segments=16, tz=0, tx=0, ty=0}) => {
            let h = 0;
            return extrudeFromSlices({numberOfSlices:levels.length, callback:(progress, counter)=>{
              let level = levels[counter];
              h += level[0];
              base = offset({delta:level[1], corners, segments},baseSlice);
              // DIRTY FIX for what expand does to original geom
              if(level[1] > 0){
              	if(corners == 'round'){
          	    	for(let i=0; i<segments-1; i++){
          		    	let tmp = base.sides.shift();
          		    	base.sides.push(tmp);
              	}else{
          	    	let tmp = base.sides.pop();
          	    	base.sides.unshift(tmp);
              base = slice.fromSides(base.sides);
              return slice.transform(mat4.fromTranslation([],[0, 0, h+tz]), base);
            z3dev @Ken
            @Ken Welcome!
            You’ve come the the right place, and hopefully you get some help to progress along.
            Here are a few hints to get you going.
            Polygons (2D) are created using a series of points, but the order is VERY important. The points should create an outline which rotates counter clockwise about the Z axis. This will allow further functions to operate properly.
            There’s a little section about the general orientation of shapes.
            • K Offline
              Ken
              Thanks everyone for your response, I continue to experiment and learn. Once I switched to Foxfire I can see the debug results.
              Thanks
              Ken
