    Does anyone use jscad on iPhone ?
    10 Posts 3 Posters 2.3k Views 2 Watching
      I shared this on a social media group for people to test the unfolder V2, and someone tried to run it on an iPhone and had an error. Here's the screenshot
      It is maybe because the url was changed by the social media, but on pc this link launches a browser with jscad and the script.
      z3devZ 4 Replies Last reply Reply Quote 0
        hrgdavor
        iti s hard to tell for these cases. unfortunately I do not have an iphone to test it.
          z3dev @gilboonet
          @gilboonet I often look at designs using my iPad. I don’t have any issues.
          I could view the given link. Blue cat and numbers. Should I try something else?
          gilboonetG 2 Replies Last reply Reply Quote 0
            z3dev @gilboonet
            @gilboonet I tried ‘unfold’, and the design did not finish. Instead, the browser (Safari) died.
            This often happens due to memory limitations or recursion issues. Mobile browsers are not the same as PC browsers.
              z3dev @gilboonet
              @gilboonet Firefox worked, but pretty slow.
                @gilboonet Chrome kind of worked, but died as well.
                  z3dev @gilboonet
                  @gilboonet Edge worked the best.
                    gilboonet @z3dev
                    @z3dev Thank you for the tests. I'm happy to see it running on iPad. One more test you can try is to uncheck "Show Model" and "Show dim." so you will have a 2d output, and save it. If you want to make the model, you should change "n° Scale" to a bigger value (5 or more). I've seen that on Ubuntu I can print the svg output, maybe I could split it into pages, so it won't be useful to have it on pdf. I will try to run it on an iPad pro to see why it dies with some browser, but it's a very recent model.
                      gilboonet @z3dev
                      @z3dev I'm using Firefox, and in my desktop it is slow but not on my laptop which has a recent apu (cpu + gpu). I'm going to test on others browsers.
                        gilboonet @z3dev
                        @z3dev You can also change the model, Venus has 1000 triangles and takes 30 sec. on my laptop to unfold (ubuntu with Firefox).
